Results 1 to 20 of 20
    NC
    green
    94 z28
    eBay cold air intakes worth it?
    Well, I was going to go out and spend $200 for a k&n cold air intake, but was thinking about the eBay ones last night. Can they really be that bad compared to the k&n? How hard can they be to make besides for the filter which then I could just buy paper ones?
    So it's $200 for the k&n cold air intake, or about $75 shipped for a few different models on the internet. Some even come with the K&N filters.
    Which should I do? If the K&N is actually a lot better than sure I'd get it, but I don't see how it really can be that much better.
    around
    correct me if im wrong but i dont think that there is a difference really other than the looks and you can buy kn filters by them selves at like auto zone my firend made a pvc cai with a kn filter it works fine
    NC
    green
    94 z28
    Quote Originally Posted by ichliebecamaro View Post
    Well, I don't really have a way to make my own pipes and want stainless steal. I thought the same thing about the only real difference would be the filter which is why I was asking to be sure. I figured buying a chrome stainless steal pipe that came with a k&n filter for $85 shipped would do just as good as a $200 K&N brand model. That extra $115 could pay for an underdrive pulley.
    Aug 2006
    Missouri
    94 Camaro Z28
    With K&N, you're also paying for the name. But I think most of e-bay's no-name parts are kind of sketchy. I wouldn't put those on my car. But overall, most CAI's for these motors are designed very similar, so the concept of the CAI is still the same. Just depends if you want to take the chance of e-bay stuff or pay a little more for the trusted name brand.
    Aug 2006
    Missouri
    94 Camaro Z28
    Quote Originally Posted by xinthenight View Post
    Steel will heat-soak a lot more than plastic. So, you'd be sucking in cooler air, just to heat it up again in route to the motor. I don't think you'd see any gains with that type of setup. K&N's tubing is plastic with a larger diameter to flow more air.
    NC
    green
    94 z28
    Quote Originally Posted by BlackLT1Z28 View Post
    Well, an old friend of mine bought one from e-bay for his girlfriends shitty old civic and he said it sounded good and helped some performance wise. Just a hard decision to make considering I can get a name brand underdrive pulley and a CAI from e-bay for the same price as a K&N CAI.
    Check these out and see if they look legit and which may seem more legit.
    http://cgi.ebay.com/ebaymotors/1993-...spagenameZWD1V
    http://cgi.ebay.com/ebaymotors/K-N-C...spagenameZWD1V
    Then maybe put some wrapping on it to keep it cool? Or would that not do to much?
    Aug 2006
    Missouri
    94 Camaro Z28
    Dude, its your car and your call. If you want to try it, go for it. Save yourself some dough and tell us what you think. In theory, its the same design as all the other ones out there and if you want some shiny chrome under the hood, then go for it. But K&N, SLP, and Moroso have all been used and trusted time and time again. I buy cheap clothes, not cheap car parts.
    NC
    green
    94 z28
    Well, that's the thing...I didn't even think about the steal heating up and bring warmer air into the engine which wouldn't do that well on gains. So that sort of threw my whole plans down the drain and I think I'm going back to a k&n since they are plastic. I'm not a cheapo on my car, I just figured I was getting more bang for my buck but I don't think so now. I mean...I made my WHOLE sub enclosure out of fiberglass where most people try to save at least $50 and make the bottom part out of wood.
    loyall ky
    black, and black
    04 M6
    k&n
    well k&n has alot of research and development into it and they are bolt in, and thats it, but like said in earlier post its your car so do what u want.
    FL
    ive bought a couple different CAI's off ebay, one for the DD and one for the camaro i use to have, they worked great, noticeable improvements(gas,throttle response) and they were very good quality.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    those are for a lt1 car
    NC
    green
    94 z28
    Quote Originally Posted by nhraformula View Post
    I thought you were suppose to get one that fit your car? I have a lt1 car...so...I'll get one that fits a lt1...lol.
    Either way...I'm thinking I'll go back to the K&N. Any fitting problems? I've seen some people on the web say they had problems to get it to actually fit in the car.
    FL
    i think this is the one i bought and it worked great! great fitment, great results. just make sure u give them the year cause obviously the 93's are different.
    http://cgi.ebay.com/ebaymotors/1996-...spagenameZWDVW
    FL
    i think this is the one i bought, great fitment, great results, just make sure that u give them the year cause obviously the 93's are different(no maf).
    NC
    green
    94 z28
    But wouldn't the steel get heated up from all of the heat under the hood and then warm up the air as it's going into the engine to lose gains?
    FL
    its aluminum, and the cone on the one i bought and posted above whent down farther then most CAI's and whent down to the bottom of the car and was able to get alot cooler air, it definatly made a huge difference.
    NC
    green
    94 z28
    Quote Originally Posted by ls1charged View Post
    I'll have to look at it more...sorry but I get this weird feeling that you're one of the people that go to the forums to advertise your products. I've seen TONS of people do that with those shitty tornodo products.
    LTX N20LT4's Avatar
    Cali
    10's N/A
    With me it's always been "A Cold Air is a Cold Air". People put soooo much on the kits, and they pretty much will all make the same hp. Period. There is only so much to them. On one of my previous Z's ('94), I had a K&N FIPK kit. After two bent/damaged filters (damn curbs), I swapped to a Track Racing kit I bought off E-Bay. Costs $71 total. Made just as much power as the K&N. On my current car I fabbed my own 4": same story. With those expensive kits, your paying for the name and finish, not any xtra horsepower.
    486/438
    10.68/127 N/A
    Aug 2006
    Missouri
    94 Camaro Z28
    You have to be careful about the filter hanging down too far. If its a daily driver, even through the elements, then you have to watch it sucking up water from puddles and shit.
    FL
    gee thanks! i appreciate it.
    it was kinda of inclosed so it was pretty safe that it wasnt gonna suck up any water.
  1. Cold air worth getting?
    By 02bluez28 in forum External Engine
    Last Post: 07-14-2007, 08:13 PM
  2. is Slps flow pac worth it the lid with cold air intake?b
    By showtimesteele99SS in forum Camaro / SS
    Last Post: 06-27-2007, 02:51 PM
  3. VOLANT cold air kit, 98-02 LS1 Camaros...FRA mod...*ebay*
    By STANG KILLA SS in forum Parts For Sale / Trade
    Last Post: 02-24-2006, 04:53 AM
  4. Air lids or Cold air intakes???
    By krummrey07 in forum Camaro / SS
    Last Post: 01-01-2006, 01:24 PM
