Results 1 to 2 of 2
06-27-2007, 04:15 AM #1Member
- Apr 2006
- Pittsburgh
red- 1998 Z28
Anyone test LM I vs LM II at the track ??
I know the LM I can be a bit much for some.
So SLP must have had a lot of guys wanting them to tame it down.
I just got a LM II muffler for testing, & was surprised to find that it is
restricted inside. A 2.25" pipe is a little 'loose' when sticking it in the muffler, so I'm guessing the inside diameter is at what the inside diameter of a 2.5" pipe is, or approx: 2.37".
So that's why they made the new LM, a 'modular' design, so you can switch out the LM II muffler when you what to make some power at the track. Or is it a 'marketing' move, to package the system in a smaller box ?
SLP Quote on the LM II muffler:
A bit milder without sacrificing that legendary SLP quality & power.
A little quiter than the original LM I.
Ok exhaust flow gurus... Will this perforated 2.5" pipe inside a 14" long, 4" diameter bullet muffler case, cause a HP loss ?? Or does SLP know their sh!t.
Has anyone tested both LM I & LM II at the track to see if there's a power loss ??
I have a 3" system on a 12.9x @ 107.xx car. I'll be testing this in the rear as a 'tailpipe', in my system. So it will be easy to make a few runs with it in place. Then a few more runs with it removed.
06-27-2007, 01:32 PM #2
there wont really be that much of a performance difference. i have the LM1 and the resonator is just hollow. the performance difference between the two is really only about sound (w/the LM2 slightly more refined). one system or the other will not be faster than the other. they are both low/no restriction straight through exhaust systems...
so, NO, no loss or gain in HP from one system to the other...2018 CTS-V: °°668rwhp/658rwtq°°
2013 ZL1: °°590rwhp/576rwtq°°
The Camaro Z/28 hits R&T's Motown Mile test track
By Ed Blown Vert in forum General Help - 5th GenReplies: 0Last Post: 10-30-2014, 06:40 PM -
Corvette Track Testing - Passing The Test
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 12-18-2009, 10:50 PM -
ZR1 Test Track video released
By blackhawk01 in forum Multimedia SectionReplies: 8Last Post: 02-22-2008, 01:20 PM
