Results 1 to 2 of 2
Thread: Electrical issue please help!
06-25-2007, 05:02 PM #1
After I got back from the track I noticed that my turn signals dont work..nothing no power at all...its not like they freeze like when you have a bad bulb. So I pull the fuse and the 20 amp fuse is blown. I replace it and they are fine...now the problem, when I put the car into reverse the fuse blows again. I pulled the taillights and the bulbs are fine. Does anyone have any idea where to check for the problem? Also whe the turn signal B/U light fuse blows I have no driverside brake light either which is strange cause the brake lights are on a different fuse. PLEASE HELP! TX.
06-25-2007, 06:30 PM #2Member
- Oct 2006
- Oklahoma City
00 LS1, WS6, V8 Gremlin- 96 & 98 GTPs, 64 'Cuda
If it isn't one of the bulb sockets chances are the wiring harness has a bare place in it and is touching the frame somewhere between the fuse and the light sockets. Could be an easy one to find, could be real trouble.
Best thing to do is replace the fuse with one of those 12V test lights and pull both reverse light bulbs. Now turn the key on (but don't start the engine) and observe the test light - it should be off. Put the car in reverse and the light will probably come on full.
Figure a way to watch that light (or get a helper) and start moving the wiring harnesses around as best you can, hopefully you'll find a place where when you move it the light goes back out. You'll now be very near to where the short is occuring.
Electrical Issue
By Kicker806 in forum General HelpReplies: 11Last Post: 09-23-2013, 05:41 PM -
Help: Need some help on an electrical issue
By Stephens 94 Z28 in forum Stereo and ElectronicsReplies: 4Last Post: 08-21-2013, 03:24 PM -
electrical issue i think
By Ieatstangs in forum General HelpReplies: 11Last Post: 03-22-2011, 05:57 PM -
Electrical Issue of the Century
By ls1camino in forum General HelpReplies: 5Last Post: 05-01-2009, 05:33 PM -
Electrical Issue
By McCool318 in forum Stereo and ElectronicsReplies: 4Last Post: 07-24-2008, 12:15 AM
