Results 1 to 20 of 34
Thread: Lowering question
06-23-2007, 07:50 PM #1
- Sep 2005
- Newport News, VA
Navy Blue Metallic- 2000 Pontiac Trans Am
Lowering question
Im going to be lowering my car soon after i get my TTIIs that are 17x9.5 and 17x11.
What all is necessary for lowering other than the springs and new shocks??
Ive heard panhard bar? LCAs?? control arms?
Which of these do i need?
the car is a daily driver and im lowering mostly for looks along with the new wheels so nothing extreme...
thanks
06-23-2007, 08:00 PM #2
06-23-2007, 08:26 PM #3
06-26-2007, 06:45 PM #4
I would also like to know what all i would need. Its just for looks, and I have the pro-kit and was told that i needed...
1. Rear lower control arm relocation brackets
2. Front camber plates?
What else would i need and can someone tell me where to get them at?
THANX!!!
06-26-2007, 06:50 PM #5
06-26-2007, 07:31 PM #6
06-26-2007, 08:02 PM #7
what about for the front?
06-27-2007, 07:44 AM #8
- May 2007
- So*Cal
Well nothing is absolutely needed. HOwever whenever lowering your car it throws off your rear geometry a little bit. To correct that you install an adj panhard rod. We've known many to go tens of thouands of miles without adding an ADJ PHR. At worse case your rear tires may wear unevenly.
Whenever we sold our springs we recommend the PHR. The LCAs and brackets are to help put your power to the ground and reduce wheel hop. They are not necessarily a requirement for lowering your car. But are good mods to have.
One of the most popular lowering packages we put together was springs and adj PHR combo. For those that wanted extra traction, the LCAs and brackets were the combo to get.
Good luck!Eric @ WAR (Formerly Eric @ DMS)
06-27-2007, 12:09 PM #9
06-27-2007, 12:32 PM #10
- Pittsburgh, PA
honestly, if you're doing the springs you best do the shocks at the same time-stock shocks, even bilstein aren't valved for lowering and your car will handle like a dump trunk [currently experiencing this
springs
shocks
adj PHB
I really reccomend Lower Control arms and relocation brackets too-i'm hopping like a bunny just from stop sign to stop sign on nearly stock power.
I have had great experience with board sponsor FRCBobby from Kentucky Speed-you should PM him with your needs
06-27-2007, 12:45 PM #11
06-29-2007, 05:09 AM #12
- Pittsburgh, PA
absolutely
06-29-2007, 03:07 PM #13
- Jun 2002
- Montreal, CANADA
Eugenio_SS
07-01-2007, 11:31 AM #14
- Sep 2005
- Newport News, VA
one more question!
should i get the regular LCAs or the adjustables??
07-02-2007, 10:41 AM #15
Hey, I have 18" c6 rims and it now sits pretty high. I have the pro-kit and i want to put them on this week. I dont have a lot of money to spend right now and it is just for looks. Do you think i can put them on a get an alignment done and be fine?
Thanx
07-02-2007, 01:57 PM #16
07-03-2007, 04:41 AM #17
07-03-2007, 04:44 AM #18
- Jun 2002
- Montreal, CANADA
What about it ?
If you're wondering what needs to be done to lower it, not much... just get an alignment afterwards.
I have 18x10.5 C6 wheels on all corners and as low as prokits... there is a thread lying around w/ some pix in the tire/wheel section (either 1st or 2nd page)
check it out.
07-04-2007, 10:05 AM #19
How low do you plan on going? I ask because a 17x11 will be very tight even with the adj PHR which will be a must in your application. I have a finger width's clearance on each side from the back of the tire to the inner wheel well and that is after tapping it back some ( I have 17x11 ZR1's). When I was lowered the car did not like taking inclines at an angle as the tires would rub on the inside on the wheel going up and hitting bumps at high speeds (interstate expansion joints) made the outside of the pass tire hit the outer fender lip. I had intrax 1.5's and was quite low (tops of tires were even with the wheel wells) and grew tired of the nuances quite early.
07-04-2007, 11:49 AM #20
lowering question
By barryz in forum Suspension and HandlingReplies: 21Last Post: 01-15-2012, 07:07 AM -
Lowering question
By dude2000_22222 in forum Suspension and HandlingReplies: 6Last Post: 05-11-2010, 07:51 AM -
Lowering Question
By hix5000 in forum Suspension and HandlingReplies: 8Last Post: 07-02-2009, 09:03 PM -
Lowering question
By TexasLS1 in forum Suspension and HandlingReplies: 2Last Post: 01-05-2009, 02:22 PM -
Lowering Question
By jimmy77611 in forum DrivetrainReplies: 1Last Post: 03-13-2007, 05:37 AM
