Results 1 to 2 of 2
06-23-2007, 07:23 PM #1Junior Member
- Jun 2007
- Broomfield, Colorado
Black- 1996 Chevy Camaro
Windows and Stereo Power cuts out
I was wondering if anyone else is experiencing this problem. My boyfriend has a 1996 Camaro and over the last year when he hits a bump in the road the stereo and electric windows quit working. Hit another bump and the power returns. He has taken it to the dealership several times for this problem but they can't seem to replicate it. It is now to the point that the power to these two items only stays on for a couple of seconds when the car starts or when a bump is hit and then it's gone again, so I guess you could say that it is getting progressively worse. He had the power window motors replaced last summer (they were worn out and the windows would take about 15 minutes and a lot of babying to get them to roll up) but this problem was there prior to the new motors and continues.
It sounds like a loose connection or broken wire in the wiring harness. Does anyone have a suggestion as to where to start the trouble shooting process?
06-24-2007, 07:48 AM #2Member
- Mar 2007
- Chicagoland/Champaign
Red- '97 Z28 M6
loose power or ground connection to the BCM, which is responsible for retained accessory power (RAP) -- more common problem than you would think
usually the BCM isn't bad, and hopefully not -- as the replacement process for that isn't simple -- have him check wires first.
Question: Stereo + Windows Stop Working Randomly Ctd..
By scStormChaser in forum Stereo and ElectronicsReplies: 4Last Post: 09-16-2014, 07:34 AM -
Help: Stereo and power windows losing power randomly
By Woodles in forum Stereo and ElectronicsReplies: 5Last Post: 10-11-2010, 12:00 PM -
Power windows and stereo
By BWA2110 in forum Stereo and ElectronicsReplies: 5Last Post: 08-23-2010, 09:25 AM -
Windows go dead, radio cuts off....!
By IronBird in forum General HelpReplies: 8Last Post: 01-26-2008, 09:42 PM -
CD player cuts out and windows won't work
By BWA2110 in forum Stereo and ElectronicsReplies: 4Last Post: 06-05-2007, 06:41 PM
