Results 1 to 1 of 1
Thread: built 4l60e and rear end fs
06-22-2007, 08:14 AM #1Junior Member
- Sep 2005
- tulsa
- iTrader
- 1 (100%)
pewter- 2000 z28 camaro
the transmission is a stage 4 4l60e built by extreme performance in okc. it has about 3k miles on it. if you are converting to a4 from m6 i can hook you up with some swap parts also. parts list
Overhaul w/ Performance race clutches w/ Kolene steels
Shift kit (firm shifts)
Kevlar 2-4 band
Torque drive kit Includes:
Hardened input shaft & housing
Extreme duty reverse reaction shell & bearing
Hardened overrun piston
29-element dual cage forward sprag
Low & Reverse roller clutch (sprag)
Super servo
High output pump slide spring (better pump volume)
Servo release valve (helps prevent 3-4 clutch burn-up)
5 pinion input carrier (front planetary) 24218063
5 pinion reaction carrier (rear planetary) 24227002
Extreme duty reaction carrier shaft
Spacer plate
Filter kit
$1400
rear end is a 10 bolt with 3.73's and a nice aluminum dif cover. has less than 3k miles on it since gears, all new seals and bearings and dif cover were installed. the car had no traction control. the rear end will come complete from caliper to caliper. the calipers have been clearanced for a set of 15" wheels. worked great.
$400
will consider trades or partial trades for
t56
mezier electric water pump
5.3 or 6.0 engine(prefered trade)Last edited by smax; 06-22-2007 at 08:33 AM.
Question: 4L70e or built 4L60e?
By ls1k5 in forum Automatic TransmissionReplies: 1Last Post: 01-15-2016, 03:20 PM -
Fully built tci 4l60e trans
By Nastyls1 in forum DrivetrainReplies: 0Last Post: 11-18-2012, 06:20 PM -
where did you get you're built 4l60e?
By jsmith564` in forum Automatic TransmissionReplies: 4Last Post: 02-05-2011, 11:13 AM -
Built 4L60e-TransBrake?
By Z28boy2000 in forum Automatic TransmissionReplies: 6Last Post: 10-19-2009, 07:41 PM -
Built 4l60e 3500 stall!!!
By Rickys S/C Z28 in forum Parts For Sale / TradeReplies: 9Last Post: 04-13-2009, 06:08 PM
