Thread: gas smell !
06-21-2007, 11:27 PM #1
gas smell !
hey guys..i recently noticed a gas smell around and in my car..had some problems with the fuel pump..so i changed it..now am smellin an awfull gas smell in my car..as if i have a gas station in my car !! also the the exhasut smells as if the engine isnt burin all the fuel..even though the car is runin fine
does any1 had the same problem b4 ??
thx in advance guyz
06-22-2007, 02:48 AM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Check your evap cannister connections.....it may have "burped" gas into it....
06-22-2007, 07:33 AM #3
dude thx for ur input..but can u tell where the evap canister location ?
btw at the speed of 50-60 miles when u give it part throttle u feel like shes hesitating badly
06-22-2007, 09:36 AM #4rednariGuest
gas smell
The evap can is attached to the undercarriage above and in front of the differential. You will find two hoses attached to the tank. One goes to the motor (3/8ths), while the other bigger line goes to the canister. Hope this helps. Red
06-22-2007, 09:43 AM #5rednariGuest
fuel line
This one is for Sarge. A while back you featured a posting showing the bent and restricted fuel line on your GTO. You replaced the pos plastic hose with
a stainless steel braided line if I remember correctly. What size fittings and hose did you use, as well as what type: compression coupler etc. Thanx for any info in the topic. Red.
06-22-2007, 11:31 AM #6Grand Imperial Wizard
Yup....and by the way...EVERY 04/05 and 06 I have looked at has the same kinked POS hose....EVERY ONE OF THEM.....
Here is the stock POS...........
Here is the replacement hose/fittings we got from NAPA......
Up front is the NAPA hose with -8AN fittings................
06-22-2007, 02:00 PM #7rednariGuest
gas smell
Yes, that's the pics I remember. You got the replacement at Napa?? You mean the hose and then you used the old clip fittings. The replacement looks so much beefier, and it should flow better too. The hose is AN 8, so I think I will try that size compression coupler on each end and then connect the tank to the chassis hard line with a Russel braided hose and fittings.
I wonder if the forum member above, with the gas smell, also has a kinked hose??Last edited by rednari; 06-22-2007 at 02:08 PM.
06-23-2007, 03:22 AM #8Grand Imperial Wizard
Probably
06-23-2007, 09:49 PM #9
well sarge after 1 whole day of checkin..we found nothin
no leaking..no kinked thingz or wateva..so i was sure that the pcm is goin rich..well unfortunetly the damn dealer told me to check up on the pcm, i have to take off the lth, catback and the cai.. so m givin up on it SARGE ..i was planing to get allen tune..will he be able to fix this bitch ??
06-24-2007, 09:10 AM #10
i reset the pcm..the car now is better than b4..but the gas smell still exists..my best guess is it either 1-bad maf sensor(even though its cleaned) 2-pcm is pumpin more fuel than needed..
i got 4 exhaust tips..at every tip its gettin dark as charcoal..and u can c alot of fuel drops on ..check the pics ..sarge i ask agian..plz help m almost givin up on this issue ..the car is drinkin fuel as hell.. I SAY IT AGAIN..NO LEAKS OR KINKS FOUND !
06-24-2007, 08:55 PM #11
thats it this thread is over..i opened the engine plastic cover..to see that the small pin in the end of the fuel rails is leaking as hell..changed the pin n its fine now, thx for every1 input
06-25-2007, 07:12 AM #12Member
- Jun 2007
- loyall ky
black, and black- 04 M6
fuel smell
glad to see u got it fixed
i smell gas
By damianj03 in forum External EngineReplies: 13Last Post: 04-03-2010, 01:57 AM -
I smell gas
By northslider in forum General HelpReplies: 17Last Post: 01-28-2010, 04:18 PM -
New Car Smell!
By Ryanater in forum Showcar and DetailingReplies: 17Last Post: 04-24-2007, 05:26 PM -
gas smell
By 94redmaro in forum General HelpReplies: 5Last Post: 01-17-2007, 05:17 AM -
Car Smell !!!
By Solidify in forum Firebird / WS6Replies: 5Last Post: 10-30-2006, 10:31 AM
