    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    Finally Cam finished!
    Got it all bolted back together now. Holds a steady 50 psi hot at a 600-700 idle. Had to drill all the way out to a 1/4 tb hole but she will finally idle with enough persuasion. Sounds wicked as hell. Definately louder exhaust and drivetrain wise. Did a few heat cycles before I took it out for a drive and still let it run at 2k for about 10 minutes to make sure everything seemed OK before I drove it around. Untuned it still will pull like a damn train until I hit my max speed of 77 MPH (2.73-4.10 gear change = hit 118 governor at only 77 actual MPH). But very impressed and definately pleased with it and the newfound power which I know I haven't fully extracted yet because of the tune and RPM and speed limits currently on the car. It is a little lopier than what I figured a 114 LSA cam would be but oh well. Turns heads big time! Going to drive it to work this weekend to put some more miles on it before I start beating on it too much. Now I can get around to the fuel pump, injectors and Nitrous, then a good dyno tune. Cam is MS3 on 114 LSA btw.
    Glad you got it finished up. I wouldn't beat on it period until it's tuned. Have you logged it yet to see just how it's running?
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    Not yet going to put a few normal miles on it. Trying to save up and work some more so I can hurry and get it tuned. Cutting off at 77 MPH sux big time (gear change).
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    good deal
  1. Finally finished it up!
    By silverWS6 in forum External Engine
    Last Post: 06-07-2010, 12:11 PM
  2. Finally got my exhaust finished!!
    By smkn gts in forum Firebird / WS6
    Last Post: 03-27-2010, 07:19 PM
  3. Finally Finished! (pics)
    By GhostofKrypton in forum Appearance Section
    Last Post: 07-29-2009, 11:35 AM
  4. finally finished my cme tonight
    By camarojunky74 in forum Camaro / SS
    Last Post: 10-11-2007, 04:51 PM
  5. Finally finished my Audio System
    By Walking-Dead in forum Stereo and Electronics
    Last Post: 05-01-2006, 11:05 AM
