Results 1 to 17 of 17
    tattoo artist,esquire sic2001's Avatar
    Huntington Beach, California
    navy blue metallic
    2001 trans am
    fastest way to launch with Auto 4 spd?
    Hey fellas,
    I was just wondering what is the fastest way to launch off the line, and from a 20 mph roll. Is it better to start in 3rd, traction control on or off...that kind of thing.I have 285/40/17 bfg kdw tires (new) and no stall or kit.
    Retired Outlaw Sum Bitch
    Launch from 3rd with TC off. 3rd engages all the clutch packs versus drive that only engages three of them....
    This is my signature. It is mine. Nobody else has one like it.
    Michigan
    1994 Camaro Z28
    Launching in any "range" other than OD or 4th/drive...will engage the manual clutches ...all stronger than the "sprag" clutches which are operative in drive position. In theory, shifting it manually for each gear ...using 2nd then 3rd..then drive...helps the tranny shift more positively, less slippage. IN my car (94 A4 Z28) the shifts are dang positive even in OD position, and especially the 1-2 shift...gets the tires loose if you're not on really good surface.
    O yeah...definitely turn off the traction control...use your own "feel" to modulate wheelspin.
    navy blue metallic
    2001 trans am
    so its not excessivley hard on the trans to shift myself? Why have I gotten to age 37 and not known this? LOL im gonna do some practicing tomorrow, any techniques I should know? I KNEW I should be dusting a couple of these cars off that got me off the line....NEVER AGAINNNNNN
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    According to everything I have ever read, the 4L60E does NOT like manual shifting!!
    Rockford, IL
    along the same lines, will shifting the 700r4 manually also enguage more clutch packs than in D or OD?
    Georgia
    2014 Camaro 1LS
    I will try from 3rd and post the results lol
    Michigan
    1994 Camaro Z28
    Quote Originally Posted by ATCharming View Post
    It is more of a case of "different" application of clutches.. sprag or overrunning clutches are typically used in D or OD, whereas direct apply clutches are used in manually selected ranges.
    Michigan
    1994 Camaro Z28
    manual shifting 700R4
    Quote Originally Posted by rbob93 View Post
    I think this is true for daily driving...too much busyness in the management system. For ones acceleration sprints, I believe it is less likely to invoke clutch failure using the stronger clutchpacks rather than sprag clutches.
    Any furthere input is appreciated...however...I am still learning.
    You are correct...launch in 3rd and manually shift to 4th....
    Member SuPeRmAn23's Avatar
    Mission,TX
    2002 camaro z-28
    what i do when im rolling twenty...i drop it to 1st and go from there...takes off really fast...
    Member SSpdDmon's Avatar
    Farmington, MI
    SOM
    '01 Camaro SS
    I always raced my A4 from OD when I had it. It actually shifted more accurately there for some reason. If I left it in D, then it would have more of a tendency to kiss the rev limiter. Besides, in an electronically/PCM controlled transmission, why would it make a difference whether D or OD was selected???
    Rockford, IL
    my third gen revs to about 7k... im assuming thats not right since the redline is like 5500 haha.
    idk why it does it... maybe my tach is off? is that possible?
    anyways... with the 700R4, its got 1, 2, D, and OD. so since manually shifting is bad, but u get better results, and ur all saying to go from 3rd, should i go from 2? then manually shift to D when necessary?
    navy blue metallic
    2001 trans am
    trans says 123 and drive on my shifter, other years/models vary. Thanks for the info!
    GMPP LS6 crate motor,racetronix,Wilwood 6 piston,HID's,200mph speedo,full dynomat, GY F1's,17" Y2K, Alpine audio upgrade,3" ele cutout, LT's, catted-Y, full suspension
    Michigan
    1994 Camaro Z28
    sarge ...good to hear from u again...dont be a stranger
    Georgia
    2014 Camaro 1LS
    I cant tell a difference. But it sounds good no matter how I launch lol
    navy blue metallic
    2001 trans am
    tach CAN be wrong, the boob who put the white gauges in my car messed it up so its 1000 rpm off. Ive just been too lazy to tear it open and correct it.
  1. Launch RPM?
    By WS6ICK2K in forum Drag Racing
    Last Post: 11-22-2015, 10:07 AM
  2. best way to launch an auto?
    By bluefields88 in forum Automatic Transmission
    Last Post: 11-01-2007, 02:23 PM
  3. Replies: 22
    Last Post: 11-26-2006, 08:54 PM
  4. Launch in an auto
    By 00ls1bird in forum Drag Racing
    Last Post: 03-10-2006, 09:18 AM
