Results 1 to 14 of 14
Thread: torque converter..
06-18-2007, 01:21 AM #1
torque converter..
i have a couple of questions.....what do they mean in "stall"...and which ones would you guys recommend me getting...i have the car as a daily driver..and well i also want it fast...right now i have headers and. lid....getting a camshaft soon..s.thx!
06-18-2007, 03:06 PM #2
06-18-2007, 04:56 PM #3
what type of stall does the Camaro have stock? compare to that 3500 how much difrent fuel millage would it get?
06-18-2007, 05:22 PM #4
- Nov 2006
- Broken Arrow, OK
I believe the stock convertor is 1800, I am not positive on that though. If you do a lot of in town driving the bigger convertor will reduce your MPG to 15/16 MPG probably. You will still get good MPG on the highway though because the convertor will lock up at a certain speed and your RPMs then drop.
06-18-2007, 05:24 PM #5
06-18-2007, 06:34 PM #6
06-19-2007, 05:25 AM #7
how bout a Trans Brake?... does that make any difrence... can it even be installed in a seemingly stock trans...or rebuilt one?
06-19-2007, 12:16 PM #8
- Nov 2006
- Broken Arrow, OK
I would look into swapping for a th350 or th400 if you want a trans brake.
06-19-2007, 12:17 PM #9
poop...stall it is... LOL
06-27-2007, 07:02 PM #10
The stock coverter (aka door stop) is 1650 RPM stall.
SteveC
06-28-2007, 05:23 AM #11
06-30-2007, 03:35 AM #12
06-30-2007, 04:43 AM #13
07-04-2007, 06:21 AM #14
Usually 550-900 depending on size stall application etc.
My Toy 00 Z28 1SC A4 - MS3 cam with supporting valvetrain, Milled LS6 heads, LS7 lifters, , ARP rod and mains, All free mods, pacesetters, True duals, moser 9 with 4.11's and Detroit Locker, Vig 3600 tuned, tubular SFC,adj PHR, LCA, adj TA, PHR reloc, LCA reloc. all with poly bushings, ZR1's and Nitto DR's (315).
My other toy 05 GTO LS2 M6- Comp XR269HR cam, 918's, hardened pushrods, Dart Pro 1's, pacesetters, X-pipe, flowmaster 1 chambers, TSP oil pump, Tick master cylinder. Pedders RR bushings, end links, SB bushings, tie rods and strut mounts, total performance poly F&R bushings. Polk DVC 12", Infinity Kappa 6.5 component and 6x9's with corresponding amps.
Her toy 77 F100-6.6/c6. All original (for now)
Question: Torque Converter
By thechad125 in forum Firebird / WS6Replies: 16Last Post: 03-12-2011, 09:28 PM -
Question: torque converter
By tangkiller_z28 in forum Automatic TransmissionReplies: 3Last Post: 02-11-2011, 01:38 PM -
Torque converter
By American Revolution in forum Automatic TransmissionReplies: 3Last Post: 02-16-2010, 07:51 AM -
torque converter??????
By bigbucks39 in forum Automatic TransmissionReplies: 10Last Post: 08-08-2008, 11:25 AM -
Torque Converter
By WS6ICK in forum Automatic TransmissionReplies: 2Last Post: 04-01-2007, 11:12 PM
