Results 1 to 11 of 11
06-16-2007, 01:50 PM #1Member
- Mar 2007
- Chicagoland/Champaign
Red- '97 Z28 M6
* final INSTALL PICS of custom single 12" partial well box enclosure *
Decided a new thread would be best for this since the other one was loaded with progress pics that probably take forever to load for some people -- just need the new amp for now -- the other one mounted here is for my front components (note that nothing is wired).
- In short, the reason I did this was so that I could run a single 12", maintain trunk space, and have a stealth look by allowing the well cover to cover it when I want to hide it.
06-16-2007, 07:38 PM #2Senior Member
- Jul 2006
- Greene, Iowa
Red- 99 Chevrolet Camaro Z-28
whoa man...thats pretty damn cool. its really niclely done. awesome craftsmanship and skills on that. id almost say id take one but i want dual 12's so im out
but ayways, awesome job, keep up the great work
06-16-2007, 10:26 PM #3
I have 2 12"s and it no cake walk, cant even get the spare tire out, even if i take the sub box out...
Regards,
Todd
#cajunhotrodder on instagram
06-18-2007, 12:24 PM #4Detailing + Design
- Pittsburgh, PA
you know...they sell stealth boxes that fit in the little cubby-you didn't need to fab one?
06-18-2007, 03:01 PM #5Member
- Mar 2007
Red- '97 Z28 M6
Why does everyone tell me that?
1 - I don't have $112+ shipping to pay for a box I could make for under $30 (given I had glue, silicone, etc at hand and mainly just needed MDF and carpet).
2 - I wanted a 12" sub -- there is not enough volume in the cubby for a 12" sub (.6 cu.ft) and I didn't want a box visible in the hatch since I plan on having my car down on campus next year.
3 - I have another amp I hid there (yes I know there were other options for this, rear amp rack, etc....) that powers my front components (well...I'm putting those in right after I type this).
4 - I wanted to try something different and felt that this was the best way to have a 12" sub and still maintain trunk space under the sub and amp rack.
07-01-2007, 08:06 PM #6
07-07-2007, 03:04 PM #7Member
- Mar 2007
Red- '97 Z28 M6
Box and amp board possibly for sale soon -- would need 2 boards/rails/whatever you can think of to run across the well for them to sit on to make this work.
Reason: I was not satisfied with the TC-9 driver and will be getting a TC-2000 instead, thus needing/wanting a larger box.
Quick Details: sealed, ~.85 cu.ft without a driver installed, fiberglass included if desired, 11" cutout diameter
PM if interested or if you have questions -- more build/install photos available here: http://picasaweb.google.com/fredmr
07-07-2007, 08:30 PM #8
How is the Bass? I found if my subs are pointed like that, bass sounds like doo. With my flip up box I have to put a board under the side closest to the seat to direct sound back toward the hatch, then it sounds good again.
07-07-2007, 11:43 PM #9
I found myself in the same predicament. I wanted a lot of bass, but wanted to sacrifice as little trunk space as possible; I also wanted to keep a place to store my t-tops. I also didn't want to spend a lot of money, but I wanted a clean look, as well as little or no hassle getting at the trunk space. The cover I fabbed looks good, too; not like that OEM flapper-thing.
07-08-2007, 02:29 AM #10Member
- Mar 2007
Red- '97 Z28 M6
thanks I guess......I'm well aware of the stealth boxes though...and also the fact that they are almost $100 more than my box and can't house a 12" sub
07-08-2007, 02:32 AM #11Member
- Mar 2007
Red- '97 Z28 M6
really? My old sub box fired at the hatch, and this one sounds much better IMO. I did try this one up above firing at the hatch though and it didn't sound as good... There are probably some angles it sounds good and bad regardless of positioning -- just due to the angles of our hatches. The next one I build will be in the same location -- but will go to the bottom of the well instead....I think that might help with sound, as I've heard boxes entirely in the well sound the best.
Custom HUmount install in Pics
By sjsingle1 in forum Stereo and ElectronicsReplies: 16Last Post: 07-06-2013, 02:11 PM -
12L7 in a custom box for f-body "PICS"
By maxwax in forum Stereo and ElectronicsReplies: 3Last Post: 07-29-2009, 06:27 PM -
Custom 2 stage dry kit with write up and " Pics"
By maxwax in forum NitrousReplies: 5Last Post: 07-17-2009, 07:55 AM -
*** CUSTOM 12" partial well box enclosure... PROGRESS pics inside^^^
By fredmr85 in forum Stereo and ElectronicsReplies: 6Last Post: 08-04-2007, 08:54 PM -
12" box INSTALL -- progress PICS (partial rear well box)
By fredmr85 in forum Stereo and ElectronicsReplies: 14Last Post: 07-01-2007, 07:57 PM
