Thread: speaker vibrations
06-11-2007, 11:07 AM #1
- Oct 2006
- Collegeville (Philly)
Black- 98 Trans Am M6
speaker vibrations
I've read on these boards before about people complaining about some vibration noises coming from their speakers. Currently I'm noticing some vibration when I turn up my bass a little in the speakers that are next to the backseats.
Is this a common problem with our cars? Is it due to crappy speakers, or is it due to plastic interior panels? Has anyone tried dynamatting these areas to see if it eliminates the vibration?
Also, I currently have a speaker amp powering these speakers since some genius of a previous owner thought it'd be cute to cut off the speaker mounting brackets to the 6 x 9s that I should have in the hatch. Could the extra power be a factor in this too?
Thanks in advance for the help!
06-11-2007, 02:31 PM #2
- Mar 2007
- Milwaukee
Red- 2000 Trans Am
Its common
06-11-2007, 03:10 PM #3
- Mar 2007
- Chicagoland/Champaign
Red- '97 Z28 M6
huh?? you shouldn't have 6x9s in the hatch (OEM)....try to reword that I might have missed something
Of course things vibrate -- that wouldn't make speakers crappy...just happens -- some cars worse than others -- with a stock setup, it should be possible to get rid of most vibrations with sound deadening, and maybe some acoustically transparent foam.
06-12-2007, 04:33 PM #4
- Oct 2006
well I'm no genius when it comes to sound but i always thought when a speaker was blown it makes a fuzzy/vibration kinda noise, so i thought it might be a possibility. when i say hatch, i mean in the trunk area. sorry, i was being rather vague.
i'll probably get the backseat area matted with that sound blocking stuff when i get those speakers put in...hopefully that'll fix the issue.
06-12-2007, 05:51 PM #5
- Mar 2007
Red- '97 Z28 M6
Sometimes it does - sometimes it doesn't -- you should be able to tell the difference though -- try listening closer?
just fyi, blown by definition though is zero driver movement, infinite resistance, etc. (ex. no sound at all)
06-13-2007, 06:25 PM #6
Dynamat
Dynamat
Dynamat
vibrations grrr
By mike ciba in forum Automatic TransmissionReplies: 0Last Post: 10-18-2010, 04:49 PM -
new wheel vibrations at 60+mph
By travisanthony07 in forum Wheels and TiresReplies: 3Last Post: 06-30-2009, 08:10 PM -
strange vibrations
By karpetcm in forum Internal EngineReplies: 8Last Post: 11-06-2008, 06:42 AM -
Vibrations
By blomeup647 in forum Camaro / SSReplies: 10Last Post: 09-19-2007, 09:43 AM -
isulation for vibrations??
By 2MuchFun in forum Stereo and ElectronicsReplies: 3Last Post: 08-17-2007, 08:52 PM
