Thread: Need cam advice
06-09-2007, 12:00 PM #1
Need cam advice
I have a 98 ws6 t/a . All I have now is a lid, filter, gears 373, and small converter , I have a a4. In the future I want to upgrade to full length headers, and duals. I will also replace the cam and intake. I need to run 12's! Without nitrous.
What cam would be best for me ?
I know I would need a tune also.
This will be a dual purpose car, I autox it and drag it.
When the cam is changed , what else should I change since the motor will be torn apart?
Thanks.
06-09-2007, 02:49 PM #2
You don't need to change the cam to run 12s.
06-09-2007, 02:54 PM #3Slow'er'Ass
- Thornton, CO
If you AutoX with it....you will probably want a cam that gives a nice flat curve.
I am thinking something like 224/224 580/580.
Get headers and a sticky tire and you won't need the cam to go 12's though.
06-09-2007, 03:05 PM #4
I am only able to run 13.6 @ 104 now. I have been told it is a slow track. Do you think headers and tune will get me close? I want to stay away from drag radials unless I can find 2 rims for cheap.
06-09-2007, 03:07 PM #5Slow'er'Ass
- Thornton, CO
Headers can knock off .2-.3.
Tune will probably knock .1-.2 off.
Some decently sticky tires and you should be there.
06-09-2007, 03:08 PM #6
Sounds like a plan. Maybe this winter I will do the heads and cam and look for 11's!
06-09-2007, 03:10 PM #7Slow'er'Ass
- Thornton, CO
What stall??
06-09-2007, 03:13 PM #8
I am not sure , how could I get an idea? It was installed by the previous owner when the tranny was gone thru. I do not think it is very big though.
06-09-2007, 03:29 PM #9Slow'er'Ass
- Thornton, CO
Press the brake down as far as you can with the car in drive.
Press the gas with the brake down. How high do the RPM's go?
A stall allows more RPM when you leave the starting beam.
06-09-2007, 04:45 PM #10
That is what I have heard. I will try that next time I drive the car.
So when the tires start to break loose at the rpm , would that be my stall?
06-09-2007, 04:49 PM #11Slow'er'Ass
- Thornton, CO
Not a fool proof method, but basicly.
06-09-2007, 05:12 PM #12
Need advice, possibly legal advice
By JHayesLS1 in forum Almost Anything GoesReplies: 36Last Post: 12-19-2009, 09:23 AM -
Need serious advice...alot of advice. Long.
By !!!FAST!!! in forum Almost Anything GoesReplies: 0Last Post: 10-31-2007, 07:49 PM -
Need ADVICE
By dblanch35 in forum Automatic TransmissionReplies: 1Last Post: 12-16-2006, 10:56 AM
