Results 1 to 13 of 13
Thread: Good way to lower.
06-09-2007, 10:10 AM #1
Good way to lower.
What is the best way to lower our cars? I want it to be done right while still having a nice smooth ride.
06-09-2007, 11:21 AM #2Just me
- Nov 2006
- Broken Arrow, OK
Springs of your choice, shocks(re-valved bilsteins, Konis, KYB adjustables), adjustable panhard to re-center the rearend, lower control arms with re-location brackets should get you fixed up. You will possibly need a front end alignment as well.
06-11-2007, 11:46 AM #3Junior Member
- May 2007
- virginia
white- 98 trans-am
Y2k,
When i got my car, it was already lowered. I have a squeaking noise in the rear end when i turn sharp to the right or left. Could this be because the guy didn't do the adjustable panhard to recenter the rearend? Also, are the adjustable lower control arm relocation brackets a must? Any help on this would be greatly appreciated. I'm a greenhorn when it comes to the new stuff but i'm having lots of fun learning. I see it doesn't take a whole lot to make these cars git up and go.
06-11-2007, 12:34 PM #4
if this were to get moved to suspension and chassis, you would get alot more replies...
06-11-2007, 02:50 PM #5Junior Member
- May 2007
- virginia
white- 98 trans-am
06-11-2007, 02:55 PM #6Just me
- Nov 2006
- Broken Arrow, OK
The adjustable conrtrol arms and relocation brackets are not a must, but beneficial to do. The adjustable panhard is a must IMO if you are lowering. Its really hard to say for sure whether the lack of an adjustable panhard is the cause of your squeaking noise, but its a possibility. It could be lots of other things as well. I would definately invest in an adjustable panhard for now and get your rearend centered up and see if that stops the squeak noise. If it doesn't then you know to look into other areas for your squeak. Hope this helps some.
06-11-2007, 05:40 PM #7
mac addair:
I went with the non-adjustable control arms...no issues what-so-ever.
I did not go with the relocation brackets...no problems
Went with an adjustable panhard...had to re-center the rear; car is lowered
Control arms with polyurethane bushings can sometimes make creaking noises. Also, a set of subframe connectors can reduce/eliminate creaking
06-11-2007, 05:44 PM #8
My car isn't lowered but I have the Blistin Suspension and I love it.
06-11-2007, 06:36 PM #9Junior Member
- May 2007
- virginia
white- 98 trans-am
06-11-2007, 06:38 PM #10Junior Member
- May 2007
- virginia
white- 98 trans-am
06-11-2007, 07:20 PM #11Crazy Canuck !
- Jun 2002
- Montreal, CANADA
select the springs that meets your needs than chose shocks that will dampen those springs well.
Eugenio_SS
06-12-2007, 03:49 AM #12Junior Member
- Jun 2007
- fresno, ca
depending on how low you go the relocation brackets can be a must. your lca needs to be level at ride height, or close to it. if you slam it, and dont reposition the lca your instant center will be all screwed up and cause mostly acceleration and traction issues.just try to keep that bad boy level and you should be fine. as far as the squeek it could be anything, but like ss said start with a track bar and recenter your rear end if you have poly bushings and they are in a bind they will squeek for sure. hope this helps.
06-12-2007, 06:20 AM #13
Pick out some springs with the rates that will be good for you (street, track, both) and then select the right shocks to dampen the new set-up!
Help: Must lower my SS...
By Raptor Avionics in forum Suspension and HandlingReplies: 2Last Post: 08-20-2010, 06:17 AM -
To lower or not to lower?
By b.lee in forum Member's RidesReplies: 34Last Post: 07-16-2008, 08:13 AM -
WS6 Lower Ram Air box
By miraclesLS1 in forum Parts Wanted / TradeReplies: 1Last Post: 04-12-2008, 05:55 AM -
lower tire press. higher ET, higher press lower ET???
By greatwhiteZ28 in forum Drag RacingReplies: 1Last Post: 10-20-2007, 05:57 PM -
To lower or not to lower...
By DLove23 in forum Suspension and HandlingReplies: 8Last Post: 04-25-2007, 07:33 PM
