    Member sscrazy's Avatar
    Warren MI. (detroit area)
    00 camaro ss
    9" rear? is it impossible to use stock brakes
    I was told that I will not be able to use my stock breaks when using a 9" ford rear end. Is that true? if not do you know anyone who can make those brackets? Thanks for your time.
    I run a Moser 9" with stock brakes.
    00 camaro ss
    Hmm. did you have to get "special brackets"? I talked to a guy at jawsgear.com and he told me that I would defiantely not be able to use stock brakes because they didnt have the brackets for it. I wonder if there are brackets out there to suite me?
    Member cailey37's Avatar
    Mississippi
    1998 Pontiac Trans Am
    I have a Moser 9" also.....it comes ready to go.....all you have to do is bolt the stock brackets on.....you will lose you ABS with this because there is no place to put the sensor.....maybe that's what he was talking about????
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    Another moser 9" on stock brake hardware. Whoever told you that does not know a thing about Moser 9". You just need to use your exhisting backing plates period. Now you can't use stock lugnuts on them but brakes etc are fine.
  1. WTB: Rear LS1 brakes
    By rll2 in forum Parts Wanted / Trade
    Last Post: 04-16-2008, 04:29 AM
  2. Rear brakes on 95 TA
    By 96transam in forum General Help
    Last Post: 06-12-2007, 10:02 PM
  3. 9" rear? is it impossible to use stock brakes
    By sscrazy in forum Drivetrain
    Last Post: 06-08-2007, 04:00 PM
  4. keep stock 16"rear rims or go to 18" the wider ones?
    By greatwhiteZ28 in forum Wheels and Tires
    Last Post: 02-27-2007, 01:59 PM
  5. Replies: 7
    Last Post: 06-13-2006, 02:19 AM
