Thread: steering question
06-07-2007, 02:20 PM #1
steering question
I have about a half inch of play in my steering wheel. I've jacked it up and had my dad wiggle the steering wheel to see if anything looked wore and i have shook the wheels to see if maybe a ball joint was bad but everything seems to be tight. just wondering if anyone had any input.
06-08-2007, 06:41 AM #2
- Oct 2006
- St. Clair Shores. Michigan
Double check your tie rod ends, cause I had a similar problem.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
06-08-2007, 01:25 PM #3
thanks, i will check it out tomorrow gotta change the oil anyway.
06-08-2007, 05:36 PM #4
check the two bolts on the steering shaft. there's one that holds the end of the shaft to the rack. then, there is one up by the firewall. takes a 7/16" or 11mm socket to tighten. i forgot too tighten the one up by the firewall on my car from doing the engine swap. i have play now. will fix it tomorrow.
06-14-2007, 04:12 PM #5
06-15-2007, 08:11 PM #6
glad to have helped
Help: Steering question
By cancam99ss in forum Suspension and HandlingReplies: 1Last Post: 01-22-2012, 06:17 PM -
steering question (3rd gen)
By Ramairgod84 in forum General HelpReplies: 1Last Post: 12-13-2010, 04:47 PM -
Steering Question
By MJ42N8SON in forum Firebird / WS6Replies: 1Last Post: 10-16-2009, 11:23 AM -
steering question
By TransAm11973 in forum General HelpReplies: 5Last Post: 08-26-2008, 06:47 AM -
Steering question! Please Help!
By Christibelle in forum Firebird / WS6Replies: 0Last Post: 04-06-2007, 10:45 AM
