06-07-2007, 10:05 AM #1Junior Member
- Sep 2005
- California
Black- 1998 Trans Am
HELP! Need PCV Rubber Boot to pass smog!
Anyone know where I can get just the rubber "boot" that the PCV valve fits into for a '98 Trans Am?
It's the boot that has a metal bracket slide into it around the PCV valve and attaches to the valve cover.
I can't get this from the dealer.
I failed smog in California because my boot has a tear in it.
Any help is greatly appreciated!
Thanks!
06-07-2007, 10:54 AM #22000 Trans AM
- Sep 2005
- Tallahassee, FL
Indigo Blue- 2000 Pontiac Trans AM WS6
if your talking about the small rubber elbow? then find a piece of rubber tubing the same size and use that... i grabbed a piece of fluid hose off my grandfathers old ass chevy and heated it up to fit right where the existing one was... worked like a charm and never had a problem again
06-07-2007, 11:07 AM #3Junior Member
- Sep 2005
- California
Thanks, but it's not an elbow, it's more of an adapter....
It looks like this, but mine has a metal clip and not a wire.
They are very picky about the smog check around here. They wont let me tape it or do anything else to repair it.The dealer sells the entire assembly for around $100, but I only need the rubber boot that the PCV valve fits into.
Any help?
Thanks!
06-07-2007, 11:24 AM #4Senior Member
- Feb 2006
- Orange County, NY
if the rubber is still soft, buy some rubber cement and glue it back together. just try to rough up in between the tear a little to give the glue something to bond to.
06-07-2007, 01:10 PM #5Junior Member
- Feb 2006
- GARDEN GROVE, CA
BLACK- 2002, CAMARO Z28
Try a junkyard.
06-07-2007, 01:49 PM #6
Also, you could do the pcv valve mod - http://www.installuniversity.com
somewhere on there. I did it too mine, and works good.
06-07-2007, 05:39 PM #7Junior Member
- Sep 2005
- California
Thanks, I usually run a coalescing filter in the PCV line to catch oil....but for smog reasons I have to be completely stock during inspection.
Nobody else has had to replace this rubber boot? Thanks for any info if you know the best place to get one. I may have to hit the junkyards if that is my only option.
06-09-2007, 07:49 AM #8Member
- Oct 2006
- Oklahoma City
00 LS1, WS6, V8 Gremlin- 96 & 98 GTPs, 64 'Cuda
I've found some rather odd emisssions parts at our local NAPA. They may not have one at a particular store but ask to look through their catalogs and you might find one they can get in a few days.
Help: Help pass smog
By Rmaverickz28 in forum General HelpReplies: 49Last Post: 11-17-2010, 12:48 PM -
Question: Headlight Motor Rubber Boot
By RadarRunner10 in forum General HelpReplies: 4Last Post: 07-11-2009, 02:54 PM -
thats a rubber boot, its a boot, its a rubber boot
By tigersport14 in forum Almost Anything GoesReplies: 13Last Post: 12-23-2008, 09:48 PM -
Anyway to pass smog?
By FantaZGuy28 in forum Western MembersReplies: 8Last Post: 06-29-2006, 06:00 AM -
FS: LS1/LT1 Rubber Shift Control Boot
By Joe K. 99 Zeee!! in forum Parts For Sale / TradeReplies: 0Last Post: 01-16-2006, 10:48 AM
