Results 1 to 11 of 11
    kentucky
    2002 camaro ss
    need help diagnosing vibration
    I have recently purchused a 2002 camaro ss and have noticed a vibration in the throttle. The vibration occurs at different points throughout the low rpms. It seems to peak at 2000 rpm and go away. The vibration happens in park and in drive. Could somebody please help me with what this could be.
    Retired Outlaw Sum Bitch
    Help me out. Your at 2000 rpm in park or drive? You mean revving?
    kentucky
    2002 camaro ss
    yes once you get to 2000 RPM the vibration starts to go away
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    sounds like you have a poly eurothane trans mount.
    What Would Earl Do? Vexzer's Avatar
    Kirby, TX
    Fire
    2002 SS
    Thumbs up
    No DTC's? No strange noises? Just go out and enjoy the car. It will tell u when it's sick.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    If you're just sitting in the driveway revving it up constantly -well that's just silly. If you're doing it because you think you have a problem and you are trying to figure it out, I hope you have stopped anyway. Open the hood and look at the motor- reach over and blip the throttle. Hear or see anything unusual? Engines like this will set codes for misfire and other things- probably just your imagination.
    kentucky
    2002 camaro ss
    nope not really any noises or anything, i was talking to somebody else today about it and they mentioned that it could be the harmonic balancer or the flywheel. Do u think one of these two could be the problem?
    orlando, fl
    2014 camaro 2ss/rs
    could be.
    Berkeley, CA
    2000 Camaro SS #3574 A4
    I have that vibration too. happens between 1500 and 2000 RPM. I've always wondered what it is.
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    If there is anything wrong, good possibility it will be a mount somewhere. Balancer and Flywheel/flewplate, highly unlikely unless one of the two are warped throwing off your internal balance but you would have felt it throughout the RPM band. BTW, I did catch the park and drive deal. In park, your engine raps side to side when you snap the throttle. In Drive, you have a load and between 1500 - 2000 you see more torque. But check your engine mounts, transmission mount, and torque arm mount on the transmission. Check the rubber for any cracking or high wear.
    kentucky
    2002 camaro ss
    thx for the help
  1. need help diagnosing noise
    By ZeroXploit in forum General Help
    Last Post: 03-27-2015, 05:43 PM
  2. Need help diagnosing my LT1 (San Diego)
    By Omega Supmeme in forum Western Members
    Last Post: 05-30-2011, 04:31 PM
  3. Need Help Diagnosing a code.. Please....
    By rcorte3001 in forum General Help
    Last Post: 03-17-2011, 06:47 PM
  4. NEED HELP ON diagnosing MY 2001 Ws6
    By dabatman01 in forum Firebird / WS6
    Last Post: 08-24-2010, 05:26 AM
  5. help diagnosing ses?
    By gary26154 in forum General Help
    Last Post: 04-04-2006, 02:14 PM
