    Senior Member GottaHaveLS1's Avatar
    Connecticut
    1999 Trans Am M6
    Long tube header installation
    I'm considering long tubes for my 99 TA and i want to know if i can install it on my own. I'm pretty handy and so is my dad, but i've heard that you need to move the trans to install them. Has anyone had success with installing lt's themselves?
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    If you honestly think you need to remove a transmission to install headers maybe this isn't the job for you...
    The only thing that needs to come off is the old exhaust manifolds/cats etc. And removing the passenger side coil pack bracket gives a bit more room as well.
    Connecticut
    1999 Trans Am M6
    i think i can do it, and thanks for the advice and the rudeness.
    Member redz284u's Avatar
    Littlerock, CA
    1998 SS
    go for it man, theres nothing like doing it your self, and be patient.....take it easy, make sure u can raise the front of the car pretty high, i had to use a floor jack + 8x8 wood block to get the needed clearance to get them long tubes in, other than that you should be good, keep it slow, take your time, align the gaskets (used the old metal ones make sure u keep right orientation) and have fun.....dont forget a set of 02 sims...also good time to change your plugs and wires too......
    Charlotte, NC
    99 Firebird Formula
    Quote Originally Posted by GottaHaveLS1
    If I were really a rude person I doubt that I'd have spent any time explaining to you how to bleed the clutch in your other post
    Junior Member Uno99's Avatar
    Appleton Wisconsin
    1999 T/A
    I say go for it. I did it with my buddies help. We all have limited experience working on cars. It is pretty straight forward. Took us 3 days for a total of 9-10 hrs.
    Beast
    Guest
    Go for it. Me and a friend did it in 7 hrs, and we had never installed headers before. Just be sure you have some penetrating oil to break the bolts loose from the head (don't want to break the bolt in the head... lessons learned), plenty of breakover bars and extensions to reach everything, don't forget to remove the plugs first (duh), use new header bolts and gasket, and be ready for every single one of the header to y-pipe bolts to break during dis-assembly...
    Mark
    Member silverTA2002's Avatar
    Bradenton, FL
    2002 Pontiac Trans Am
    Nothing difficult. Just time consuming.
    With a buddy and a lift, it took us 5 hours (not including time to fix leaks/banging of y pipe).
    2002 Trans Am 6sp, SLP lid, Holley filter, Shaner S3 TB, Jet Hot long tubes and cats, FRA, HP tuners, Hotchkis STB and LCAs. TEA stage 1.5 5.3 heads, Comp 220/224 114 +2, UMI Boxed SFCs, Edelbrock PHR. Moser 9" 4.11 gears.
    **FOR SALE**: http://www.ls1.com/forums/showthread.php?t=60478
  1. Long tube Header Opinions needed!
    By SteelCityTA in forum LT1
    Last Post: 04-06-2009, 01:12 PM
  2. Replies: 2
    Last Post: 08-04-2007, 03:04 PM
  3. Long tube header help!
    By exlrep2002 in forum External Engine
    Last Post: 06-06-2007, 09:19 AM
  4. Complete Long tube header package!!! no s/h!!
    By shift_down in forum Parts For Sale / Trade
    Last Post: 09-26-2006, 06:40 PM
  5. paceseter long tube headers installation
    By adham in forum External Engine
    Last Post: 11-13-2005, 06:18 PM
