    Member Z ROADSTER's Avatar
    Shreveport,Louisiana .USA
    PEWTER
    2002 Z/28 VERT.
    Angry front running lights
    How the hell can you get to the inside of the running lights to change the friggin bulb ?
    Member cobrahunter's Avatar
    South Bay
    1998 Camaro Z28
    For me, the easiest way was to remove the headlights. I then had easy access to the housings.
    Berkeley, CA
    2000 Camaro SS #3574 A4
    I had that problem, and I just unbolted some of the black plastic panels under the front of the car and reached up and did it from underneath. took me a couple days to figure out how to get into there.
    PEWTER
    2002 Z/28 VERT.
    Thanks. Someone said there was a plastic trap door held by 2 screws. Got any pics ?
    Berkeley, CA
    no pics, but when I get some time I'll post some. probably in the next couple days.
    My Neighbors Hate Me!!! lvbroham1's Avatar
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    2001 Chevy Camaro SS
    Wink
    I believe taking out the headlight is the fastest and easiest way. I tried many other ways and that seems to be the easiest and fastest overall. It only takes about 2 minutes a headlight to take out and then you have complete access to the running light. Just make sure you don't touch the bulbs and don't pull the headlight the wrong way when taking it out. They're mostly held in with two plastic clips on the back of the headlight and if you're not careful they'll break. Hope this helps!
    Berkeley, CA
    can't you throw the headlights out of adjustment?
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    No... Only if you mess with the allignment screws that are behind the light. Just make sure that when you take them out you use the indents and marks the bolts left behind when you take them out... If you do that you should be fine.
    silver2002Z
    Guest
    only takes 30 seconds to take that trap door off....reach up in there and pull the light harness out.....never took the headlight out
  1. No running lights, dash lights
    By 77k5 in forum General Help
    Last Post: 01-07-2010, 11:35 AM
  2. Wanted: Front T/A DRL Running Lights
    By nhra-trans-am in forum Parts Wanted / Trade
    Last Post: 02-21-2009, 12:09 AM
  3. Passenger side front running/blinker lights exploding
    By rolyan76 in forum General Help
    Last Post: 04-16-2007, 06:14 PM
  4. 98-02 Camaro Front Running Lights
    By AFASTYZFR1 in forum Parts For Sale / Trade
    Last Post: 12-16-2006, 08:21 AM
  5. I Need Front Running Lights!!!
    By lrader99 in forum Parts Wanted / Trade
    Last Post: 01-07-2006, 09:13 PM
