    Senior Member
    PA
    07 MAZDASPEED6 GT
    Question Adding light weight wheels. Just how much will this help?
    Just how much would reducing my rotating mass by 14 lbs w/lighter wheels help me out? That's 14 lbs total for all 4 wheels.
    Not an f-body obviously, but same deal.
    '07 MAZDASPEED6 GT
    '96 Mystic Cobra #5615
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    it will help a good deal since the weight your saving is rotational weight which is the worst. so it would be a worth while mod. you will feel it in acceleration and breaking
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    If I remember correctly for every 10 pounds you remove from wheel tire combo its like removing 100lbs from the rest of the car. Which usually every 100lbs you remove= one tenth in the quarter mile. When you say 14lbs is that with the same tire that were on your stock wheels? Or are you going with a bigger tire? Alot of time people want or do buy light weight wheels but don't factor in the tire weight. If you stay with the same stock tires theoretically you just removed the equvalient of 140lbs from your car. If you go with a bigger tire it may be less depending on how much more the tire wieghs over the stock tire.
    Junior Member Louie's Avatar
    Ohio
    2000 WS6
    It will substantially help. Also, you need to take the radius into consideration.
    Less weight + shorter radius = much less resistance to rotation.
    Senior Member
    PA
    07 MAZDASPEED6 GT
    Quote Originally Posted by JonB View Post
    same size tire
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    just make sure the tires you chose won't add 14lbs.
    Tire weights vary extremely and they tend to be heavier than the wheels.
    it's not uncommon for tires to weight 30+ lbs each.
    Check manufacturer specs for weights.
    Eugenio_SS
  1. light weight carpet
    By SSDEUCE in forum Drag Racing
    Last Post: 12-21-2009, 08:02 PM
  2. light weight carpet and interior
    By SSDEUCE in forum Eastern Members
    Last Post: 11-21-2009, 06:05 PM
  3. For Sale: Fridanza light weight fly wheel
    By stevenm357 in forum Parts For Sale / Trade
    Last Post: 03-31-2009, 07:31 AM
  4. Light weight Flywheel?...
    By lvbroham1 in forum Drivetrain
    Last Post: 05-22-2008, 09:51 PM
  5. Good light-weight racing seats?
    By xinthenight in forum Appearance Section
    Last Post: 09-01-2007, 06:55 PM
