05-28-2007, 07:50 PM #12000pontiac6Guest
running light and blinker problem
I'm having a strange problem with my running lights. When i turn on my car one(passenger) is out but if i turn on the parking lights or just turn the lights all the way on the other one will turn on. Also, no matter how i have the lights, on or off, my passenger from blinker does not work. Could there be a bad ground? Anyone have any idea what could be causing this?
05-28-2007, 07:55 PM #2
More than likely it is burned out. Just replace it. It is a dual filament bulb which would explain why it illuminates with lights on but does not blink. It is a common occurence on our cars.
05-28-2007, 08:03 PM #32000pontiac6Guest
alright thankss
05-28-2007, 08:05 PM #4
05-28-2007, 08:53 PM #52000 Arctic White trans am, ws6 hood, ws6 air box, slp lid, slp smooth bellows, slp loudmouth exhaust,shift kit, rebuilt trans, LS6 intake, 3.73 gears, Shaner S3 p/p throttle body, and a tune . SFC. C6 ZO6 rims 18" in back 17" in front. Drilled and slotted rotors.
05-28-2007, 08:56 PM #6
It's either like TAC02 said your bulbs.. Or it's one of your bulb sockets is burnt up and not working fully.. I had problems with my blinkers working on the front, and only one of my parking lights would work, both would work sometimes.. Well I spliced a new bulb socket on the troubled side and BAM the parking lights were bright as can be and my turn signals started working perfectly... I believe is one wire on the bulb socket is messed up, it will pretty much affect the other.. Thats my .02
05-30-2007, 07:13 PM #7Junior Member
- May 2007
- Gurnee, IL
Sebring Silver- 2002 T/A FireHawk
I would check the lens and housing assembly also. I had the same problem and water kept getting in there and shorting it out.
Bruce
05-30-2007, 07:33 PM #8
10-13-2008, 11:11 AM #9
side lights
I installed an Autotrix front side marker light kit and they blink just fine. The problem is that they don't work as marker lights any more. Can anyone help? Thanks.
Daytime running/ turn signal light color problem?
By draggo in forum Firebird / WS6Replies: 13Last Post: 08-26-2008, 02:25 PM -
Fog light blinker
By ichliebecamaro in forum Appearance SectionReplies: 7Last Post: 05-10-2008, 08:32 AM -
Problem starting car after replacement a running light
By p1astik in forum General HelpReplies: 2Last Post: 06-22-2007, 03:44 AM -
running lights/blinker
By Lucky 13 in forum Firebird / WS6Replies: 13Last Post: 06-13-2007, 03:58 PM -
Passenger side front running/blinker lights exploding
By rolyan76 in forum General HelpReplies: 1Last Post: 04-16-2007, 06:14 PM
