    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    Custom PCM Programming Question
    Check my signature and give me your opinion on the benifits/gains I might expect. I can't get to a dyno tune for now and plan no more mods. Will it be worth the expense, etc?? Thanks
    2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
    P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
    337rwhp/348rwtq
    what's wrong with just using your predator? What version is it? Does it have the flexibility in it the new ones have? Timing and fuel curves? If so you should be able to get a decent tune out of that for your mods.
    Navy
    2000 Z28 M6
    Embarrassed
    I do have the Predator but do not know what the optimum parameters should be for the various settings it will allow (outside the canned performance tune loaded to the handheld). I researched on the web and forums and got little information that gave me a warm fuzzy when it came to messing with ratio's and such. That is the reason I thought a performance mail order tune might be best to keep me from tearing up a very nice engine. Embarrassed to admit it but there are some things I am a bit shy to tackle.
    give me a bit and I'll link you to some good tuning info for the predator.
    Navy
    2000 Z28 M6
    Thanks
    Thanks...I rec the information and printed same. Will give it a try when there is time to not be interrupted.
    Springfield, Mo
    Link that info my way too?
  1. Question: key fob programming
    By Butch2000 in forum General Help
    Last Post: 01-19-2011, 05:35 PM
  2. Help: Programming question
    By cat102199 in forum Manual Transmission
    Last Post: 08-09-2010, 06:59 PM
  3. custom grind question: 228/228 .600 .600 110 lsa?
    By MdFormula350 in forum Internal Engine
    Last Post: 02-08-2008, 04:52 PM
  4. Custom sub question
    By degenerate in forum Stereo and Electronics
    Last Post: 04-05-2006, 01:02 PM
  5. which programming
    By jlvf77 in forum Computer & Tuning
    Last Post: 03-21-2006, 11:38 AM
