05-19-2007, 06:33 PM #1
Toggle lights, yet have DRL working?
what if i still want DRL to work, just have a TOGGLE SWITCH mounted where most ppls tcs switch is usually mounted.......A TOGGLE that KILLS ALL lights but the foglights, i mean headlights, running lights, taillights,brakelights etc when you have the toggle to off, and when you have the toggle on the drl still works.........
WHERE DO I HOOK THAT TOGGLE INTO??
lets just say that since i have had my maro, i have been in a situation that me in my car and my buddy in his maro BOTH needed to shut our lights down....
05-20-2007, 05:31 PM #2
Just delete your autolight sensor in your dash, and connect 2 relays to your brakes and turn signals. Probably need 2 toggles but will get the job done.
05-20-2007, 06:17 PM #3
problem is i like auto lights, can i cut off electric BEFORE the drl or will it throw a code?
05-21-2007, 10:53 AM #4
You won't throw any codes. But as far as the drl, some people just don't disengage the ebrake all the way, this keeps the front running lights from coming on, and technically your ebrake isn't on either. But then you will have the ebrake light on your dash on all the time. Maybe you can tap into that somehow??
05-21-2007, 08:01 PM #5
Well, if you're trying to accomplish what I'm thinking, don't forget the lights over the license plate
05-22-2007, 05:16 PM #6
Lights not working. :(
By SouthBLVD in forum General HelpReplies: 5Last Post: 12-26-2008, 02:13 PM -
Fog Lights are not working
By bevenue in forum General HelpReplies: 0Last Post: 06-23-2007, 12:47 PM -
By 2MuchFun in forum Camaro / SSReplies: 0Last Post: 05-18-2007, 05:47 PM -
wipers not working when lights are on........
By astyles in forum Stereo and ElectronicsReplies: 1Last Post: 06-10-2006, 02:26 PM -
Fog Lights Quite Working
By Z28LOVER in forum Stereo and ElectronicsReplies: 7Last Post: 09-18-2005, 06:17 PM
