Thread: grinding and rubbing sound !?
05-13-2007, 05:48 PM #1
I just installed pacesetter l/t and ory on my 2000 t/a and it sounded good the first day but then today I noticed a kind of grinding sound when i push on the gas or turning sometimes. Could this be my y-pipe hitting my floorboard? or if its not sealed right? please help, thanks !
05-13-2007, 06:11 PM #2
Yep, It needs a chiropractic adjustment !!! They're a tight fit !!! Good Luck !!
05-13-2007, 06:50 PM #3
It's definately the Y pipe
05-13-2007, 07:09 PM #4down with the lot lizards
- Dec 2006
- Pensacola
Red- 2001 Camaro SS A4
its the little knomes screwing in the back seat
05-13-2007, 07:30 PM #5
i'm having the same problem with the same exact setup, let me know if u get it fixed, i'll do the same
05-13-2007, 08:37 PM #6Member
- Sep 2005
- Newport News, VA
Navy Blue Metallic- 2000 Pontiac Trans Am
hmmmm if ur sayin grinding noise, doesnt the y-pipe make a banging niose?
is it in the steering wheel?
i had grinding in my steering wheel after headers because they rubbed on the steering linkage....
05-16-2007, 03:47 PM #7
hmmmm
I got all the ratteling out of the engin , a heat shield was hittin the y pipe BUT I can not find out for the life of me WTF is grinding in my engine. It does not do it when you are just sitting at idel but when you drive and push on the gas you can hear it loud and clear. Does anybody have any idea what it could be??
05-19-2007, 08:21 PM #8
is it an auto or stick? Could it be the convertor locking up? What mods do you have other than headers?
05-20-2007, 04:14 PM #9
check steering linkage.
08-18-2014, 12:13 PM #10Junior Member
- May 2013
- Orefield, PA USA
Black- 2001 Trans Am WS6
My steering linkage is rubbing bad too, what did you do to fix that?
09-10-2014, 11:41 PM #11Junior Member
- Jun 2014
- Oman
White- 2001 Camaro Z28
i had the same noise and came to know its the CB which was not tightened well.
09-11-2014, 02:40 AM #12
There are a couple of areas where the exhaust is tight to the underbody or other vehicle components. Depends on which exhaust system you have as to what issues you might encounter. In a lot of cases, stock engine mounts are worn and allow the engine to sag. Replacing the mounts with polyurethane pieces is often recommended.
Question: grinding sound
By SparkyZ28 in forum LT1Replies: 6Last Post: 03-27-2012, 02:45 PM -
Question: grinding sound?
By Karczewski in forum General HelpReplies: 3Last Post: 12-28-2011, 06:38 AM -
Clutch rubbing sound when pressed when I start to slow down
By Redskin1 in forum Manual TransmissionReplies: 3Last Post: 12-08-2010, 02:19 PM -
Rubbing is not a cool sound
By LSCyaL8R in forum Wheels and TiresReplies: 2Last Post: 10-02-2009, 11:56 AM -
Rubbing sound from engine bay
By Sk8d85 in forum General HelpReplies: 2Last Post: 02-22-2007, 09:55 AM
