05-12-2007, 02:57 AM #1Junior Member
- Dec 2005
- Burnaby, BC. Canada
Blue & Silver- 1992 Camaro Z28
"NEW" ENGINE, Upgrades BEFORE/AFTER PICS & VID
Engine finally DONE!
I recently got the following done to my engine. I had 3 oil leaks in the car, Rear main seal, Oil gasket, and another leak that no one can figure out where it was coming from. Turns out it would be around $1500-2000 to fix it.. And I thought, what's the point of fixing an OLD 15 year old engine. So I set forth to get the engine remanufactured. I then decided to get a cam, ceramic edelbrock TES headers, ignition system, etc. Total $7000cdn
Here is what was done:
1 - New 5.7L V8 350 engine (Rebuilt with new Pistons, Bearings, Valves, Seals, Springs, Lifters, Timing Set, Polished Crankshaft, All new Gaskets, Including Head Gaskets, Intake, Rear Main seal, Timing Gasket and Front seal).
1 - Intake Manifold
1 - 3 Year, Parts and Warrenty (60,000km Warrenty) on all related parts.
1 - Comp Cam
http://static.summitracing.com/globa...08-300-8_w.jpg
1 - MSD Pro Billet Distributor Cap and Rotor
http://static.summitracing.com/globa...e/msd-8366.jpg
1 - BEST Rated Oil Filter - WIX :
https://web12.secure-secure.co.uk/be...s/IMG_8086.jpg
1 - MSD Wires (8.5mm) [BLUE] Heli-Core Spark Plug Wires Kit
http://static.summitracing.com/globa...e/msd-3135.jpg
8 - ACDelco's RAPIDFIRE platinum spark plugs (100,000KM replacement)
http://www.acdelco.com/i/parts/spark..._rapidfire.jpg
1 - Edelbrock (Ceramic) TES (Tubular Exhaust Systems) Headers and Kit Exhaust System with Y-pipe
http://www.jegs.com/images/photos/300/350/350-68792.jpg
1 - Stage 8 Header Lock Bolts
http://www.jegs.com/images/photos/800/868/868-8913.jpg
1 - New O2 Sensor
1 - Labour of course to fit and weld collector pipes to headers
1 - New AC Delco Waterpump
1 - New Thermostat
1 - New UPPER Heater hose
1 - New LOWER Heater hose
1 - New Intake to Throttlebody Coolant Hose
1 - New Radiator Fan Switch
1 - New Tempature Sensor
2 - New Oil Coole Gaskets
1 - New Serpentine Belt
1 - Speedy Sleeve for Harmonic Balancer
2 - Poly Urethane Motor Mounts (Energy Suspensions)
http://www.jegs.com/images/photos/35531116.jpg
1 - Coolant
1 - Oil Change 5W30
14 - Remove and Install Engine with New Components
1 - Fixed hood latch, spring, re-aligned, and adjusted Hood. [FREE]
1 - Front suspension adjustment [FREE]
1 - First oil change (6 months) [WILL BE HALF PRICE]
X - Fixed some grounding wires
X - Re-routed under light wires for a more pleasure appearance
X - BLUE Tiewrapped for needed instead of regul white or black to match color scheme of engine bay.
1 - Complete Professional Interior, Exterior, and engine bay cleaning [FREE]
!!!! - AWESOME MECHANIC. Despite some problems, all if fine now. [PRICELESS
PICTURES:
Engine back from engine remanufacturer
http://i17.photobucket.com/albums/b5...s/100_7739.jpg
Old Camshaft :
http://i17.photobucket.com/albums/b5...s/100_7741.jpg
Old valves, retainers, springs, etc :
http://i17.photobucket.com/albums/b5...s/100_7743.jpg
My old intake :
http://i17.photobucket.com/albums/b5...s/100_7747.jpg
Damaged coolant passengeways : http://i17.photobucket.com/albums/b54/camarosource/April%2017%2007%20-%20Pics%20-%20cars%20new%20engine%20and%20headers/100_7748.jpg[/img][img]http://i17.photobucket.com/albums/b54/camarosource/April%2017%2007%20-%20Pics%20-%20cars%20new%20engine%20and%20headers/100_7749.jpg
Here shows the cracks and WELDING the previous owner did (he was a welder). Surprized to see this when they opened the engine up - http://i17.photobucket.com/albums/b5...s/100_7780.jpg
Left over fasteners, plugs, etc :
http://i17.photobucket.com/albums/b5...s/100_7782.jpg
Brand New Headers :
http://i17.photobucket.com/albums/b5...s/100_7752.jpg
Old parts -
http://i17.photobucket.com/albums/b5...s/100_7753.jpg
Apparently the engine had compression leaks, running quite lean, coolant leakage inside the engine, cracked intake, welded intake with the 6 years the original owner had the car (obviously abused!)
BEFORE:
AFTER:
BEFORE:
AFTER:
BEFORE:
AFTER:
VIDEOS - May need to turn up your volume a bit as it may have recorded a bit lower
BEFORE:
AFTER:
An AFTER Video of plain driving, was DARK Outside by the time I got home :Last edited by camarosource; 05-14-2007 at 12:18 AM.
1992 Camaro Z28. Blue/silver, Custom Blue/Silver Leather seats, Rebuilt Engine, Cammed, Headers, TT ][ Rims ...
NEW WWW.CAMAROSOURCE.CA
3,500+ Camaro Information Database
http://www.camarosource.ca/small_version.jpg
05-12-2007, 11:00 PM #2
Nice car man-how much american does 7000 canadian convert to???
05-12-2007, 11:02 PM #3Junior Member
- Dec 2005
05-12-2007, 11:06 PM #4
Dude that seems like way too much money to me for basically a stock motor. How much was just the labor???? Very nice car though.
05-13-2007, 08:35 PM #5Member
- Apr 2007
- San Diego
Red- 2002 T/A
PLEASE do not wait six months for a 1/2 price oil change on a newly rebuilt motor! More like a couple hundred miles.
05-13-2007, 09:37 PM #6
05-14-2007, 12:17 AM #7Junior Member
- Dec 2005
Question: "Service Engine Soon light" Got a P0430 code
By gymrat11 in forum Camaro / SSReplies: 8Last Post: 01-09-2014, 07:42 AM -
Ohio "Greets" Bloomberg's Gun Control Bus Tour (pics)
By wileyCoyote in forum Gun's & AmmoReplies: 3Last Post: 08-30-2013, 06:51 PM -
Grand Prix GT "check engine light"
By rschap1 in forum Almost Anything GoesReplies: 3Last Post: 10-24-2008, 06:20 PM -
858Ci engine= 850hp+ "Mighty Engine"
By 6-Speeder in forum Multimedia SectionReplies: 7Last Post: 12-29-2007, 09:37 PM -
Whats the difference between a "Super Charged" and a "Turbo Charged" engine?
By Neil in forum Forced InductionReplies: 13Last Post: 10-25-2007, 04:43 PM
