05-08-2007, 11:17 AM #1Member
- Mar 2007
- RIVERSIDE, CA
GREEN 95 F/B LS1- 2000 SIERRA 5.3
HELP !! remove the doors on a 2002 yukon
hi - i was looking for advise on removing the doors from a 2002 yukon - they appear at first glance that the hinges are welded on both sides ????
thanks - shane
05-08-2007, 11:22 AM #2
Just removed the driver's door on my '97 Silverado last week. Not sure if it's the same process. All I had to do was hammer out the hinge pins (PITA) and the door came right off. Be sure to unplug any wire harnesses first if it's an electric door. The vehicle side of the hinge is welded in.
When putting the door on, use new hinge pins and bushings (bushings hammer in and out as well). You can get 2 sets (enough for 1 door) for $10 at your local auto store.
05-08-2007, 05:56 PM #3Junior Member
- Sep 2006
- s.e. ma
primer- 65 nova
yukon door removal
remove the sill plate-pull straight up from clips
remove the lower pillar trim (kick panel)_pull back towards door opening
disconnect door wiring connectors-behind the kick panel and feed them through the pillar
unbolt the door check link from the piller side-10mm head bolt
remove the bolt from each hinge
lift the door up off the pins
05-11-2007, 02:32 PM #4Member
- Mar 2007
- RIVERSIDE, CA
05-11-2007, 04:28 PM #5
hell i was gonna say torch or saws all! j/k
FS: 2002 GMC Yukon SLT. 4WD. 57K. One Family Owned.
By 98CamaroSS in forum Vehicles For Sale / TradeReplies: 1Last Post: 10-27-2012, 10:34 PM -
2002 Yukon 2wd Complete Rolling Frame For Sale - No Damage !
By LS1W in forum Parts For Sale / TradeReplies: 1Last Post: 05-14-2007, 07:25 PM -
2002 Yukon A/c Compressor
By LS1W in forum Parts For Sale / TradeReplies: 0Last Post: 05-09-2007, 12:37 PM -
2002 Z28 Black Doors And Hatch
By EvilC in forum Parts For Sale / TradeReplies: 0Last Post: 03-18-2007, 01:12 PM -
Tell me about 96-98 yukon gt two doors.
By Murder after Midnight in forum Almost Anything GoesReplies: 14Last Post: 10-13-2006, 05:17 PM
