    Junior Member tording's Avatar
    Hampton, VA
    99 Camaro
    how difficult is A4 to M6 swap
    I found a good deal on a car but it is an A4 and I really want an M6. If I was to get the A4 how difficult is the swap to an M6 including the pedal install and everything??
    Stu
    Guest
    Very simple. The hardest part is the computer issues. Everything else just bolts in. You do have to cut a hole for the master cylinder.
    sooslick graveyardman's Avatar
    S. Cali
    big red
    1995 firebird
    You'll also need to cut a hole for the shifter. The process is easy for some and hard for others. Having the right tools/equipment is half the battle.
    I tried to post a link for ya but the site says I need at least 10 post in order to do so...oh well.
    Member tici's Avatar
    Zurich - Switzerland
    1998 M6 vert TA
    I finished today to install the pedals included master cylinder...
    It's not "difficult", but it takes a LOT of time.
    Hands get skratched a lot also!
    Look at LS1TECH.com under manual transmissions (Sticky). You'll find everything you need for the swap.
  1. Difficult Question
    By kmassner in forum Almost Anything Goes
    Last Post: 01-06-2013, 06:54 PM
  2. difficult to shift into reverse
    By grouch0jr in forum Manual Transmission
    Last Post: 09-23-2008, 09:06 AM
  3. Cam, how difficult and is it worth it?
    By Heartbreak1 in forum Rocky Mountain Members
    Last Post: 08-09-2007, 07:06 PM
  4. motor mount swap..difficult? pricey?
    By 00maroz28 in forum External Engine
    Last Post: 06-01-2007, 01:28 PM
  5. the most difficult thing on earth
    By issues in forum Almost Anything Goes
    Last Post: 09-12-2006, 08:55 PM
