Results 1 to 10 of 10
    DFW
    1999 SS
    Will the stock Rocker arms hold up?
    I am just about finished with my motor swap(6.0, tsp stage 2.5 LS6 heads, tsp torquer V2 cam 112 LSA). My question is this: I have a set of the yella Terra roller rockers and want to run them, but when I first start the motor up I am going to use the stock rockers so everything will pump up with oil pressure, and then put the rollers on since you have to shim them properly. Will the stock rockers work ok with that large of a cam? I just don't want to damage my cam or any of the valvetrain @ startup.
    Member 408WS6's Avatar
    Houston
    Current best: 10.60/126.8
    1998 Pontiac TA WS6
    They should be ok. I'm using stock rocker arms on a cam with .630" lift.
    DFW
    1999 SS
    Alright. cool thanks
    Quote Originally Posted by 408WS6 View Post
    Same.
    Junior Member BIG_MIKE2005's Avatar
    Jun 2006
    Skiatook, Ok
    1999 Trans Am WS6
    If your worried get a spare set & send them off to Harland Sharp to be rebuilt. It only costs $250 + shipping there & back. Which is still cheaper than aftermarket 1.7 rockers & you get all the install benefits of the stock rockers with aftermarket performance.
    http://i21.photobucket.com/albums/b2...34244289-L.jpg
    99' NBM WS6 6-speed
    Mods:Stock bottom end-224/.581 114-TR 7.4's-P/P & milled .018" 5.3's-P/P TB-LS7 lifters-LS7 clutch-LS2 flywheel-MTI lid-Pacesetter LT's-TSP ORY-Hooker Aerochamber
    Quote Originally Posted by BIG_MIKE2005 View Post
    This is what I will be doing sometime in the future.
    Jun 2006
    Skiatook, Ok
    1999 Trans Am WS6
    Me too. Probably before the end of the month.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yes you should be fine with the stocks for the initial start up. I seen a issue but it was on a cam that was .670 or .675 lift.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    i still have a set for sale
    http://www.ls1.com/forums/showthread...ghlight=garage
    Jun 2006
    Skiatook, Ok
    1999 Trans Am WS6
    Don't need another set of stockers, sorry. I got a set locally for $30 I'm pickin up this Friday.
  1. High-Ratio Rocker Arms - Off Your Rocker
    Last Post: 08-19-2011, 02:50 PM
  2. rocker arms
    By joejenkinsglass in forum Internal Engine
    Last Post: 04-01-2011, 06:53 PM
  3. Rocker arms
    By seamurda in forum Internal Engine
    Last Post: 04-06-2010, 10:33 AM
  4. WTB: low mileage stock rocker arms
    By Superado in forum Parts Wanted / Trade
    Last Post: 01-21-2008, 06:28 AM
  5. rocker arms
    By C5_LS1 in forum Corvette
    Last Post: 03-10-2006, 10:59 AM
