    New Orleans, LA
    1997 Trans Am convertible
    Car Stalled, Help!!!
    As a result of it pouring like crazy today here in Baton Rouge, I tried driving through some water and my car stalled (97 Trans Am). Ran a diagnostic,the only code it shows is "P0103 Mass Airflow circuit high frequency".
    Could it be the opti?
    I dunno where to start
    Newport KY
    1995 Chevy Camaro
    It stalled, as in, it stoped and then u started it back up? Or it stalled as in it stopped and WONT start back up and u got it towed.
    2nd question is do u have full coverage?
    I try to avoid water in general (in the car that is ). I HATE rain. If its raining, i wont drive. If i have no choice, i drive like a old ass man. If there is a big puddle GO SLOW or change lanes.
    http://www.mlive.com/cgi-bin/prxy/we...uddleCar02.jpg
    New Orleans, LA
    stalled as in it killed and wouldn't start back up
    Sounds like the engine may have sucked water and killed the MAF sensor itself.
    SCPO - Retired joerockhead's Avatar
    Mile High
    BlackCherry
    Bad Ass 67 Camaro / 2010
    If you got water in the Opti, it is fried.
    Sorry dude.
    Junior Member Bralgar's Avatar
    Indiana
    1993 Camaro Z28
    Will it crank? Or just Click? If it will crank I'd also suspect the opti. But if the starter just clicks, pull your plugs(all of them) and pull your fuel pump fuse and then crank it, you may have hydro-locked your engine, that should clear out the water from the cylinders. Don't forget to drain your oil too, large amounts of water can seep down into the oil pan past your rings. I had it happen on an '86 Iroc I had about 6-7 years ago. It also fried the IAC.
    Brent
    1993 Z28 A4 3.23 Don't laugh, it's paid for.
    FFI SS hood, ZR28 Spoiler, SLP LoudMouth, BMR U/L A-Arms, LS1 Brake Upgrade, ES Trans mount, 1LE Elbow, K&N air filter, Holley AirFoil, and a set of C5 wide 5's with Kumho Ecsta MX's
    1966 GTO 400 ci M4 3.55
  1. Backfire followed by a stalled car.......
    By elevario in forum General Help
    Last Post: 01-06-2015, 02:46 AM
  2. Help: stalled out traction control off???
    By okay469 in forum GTO
    Last Post: 04-17-2013, 09:00 AM
  3. Stalled car in gear now won't start
    By Hurley711 in forum General Help
    Last Post: 08-18-2012, 09:28 AM
  4. Stalled M6!!!!
    Last Post: 06-25-2009, 05:43 AM
  5. Have a stalled 4l60e to swap with a t56
    By Frankthetank in forum Parts For Sale / Trade
    Last Post: 12-27-2006, 02:11 PM
