Results 1 to 20 of 24
    Member Huskerz1's Avatar
    99 SS Vert M6
    Questions for Vert owners with Roll Cages
    Welded or bolt in? Mild steel or chromoly? 4 point or 6 point? Weight?
    Info, pros, and cons please.
    Thanks
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    http://www.wolferacecraft.com/Search...?CategoryID=20
    in each one, chromoly, mild-steel, 4-5-6pt, it shows the weight.
    I went w/ the 4pt welded.
    Eugenio_SS
    99 SS Vert M6
    Why a 4 point? What concerns, if any, have you had since having it installed? Did you go with mild steel or chromoly? Why? What does the car feel like after installed? Why did you weld instead bolt on? How is the carpet affected? I'm assuming a bolt on will sit on top of the carpet. Will a 4 point be legal at the track?
    Your reply is pretty generic. Please expound, eh?
    Jun 2002
    Montreal, CANADA
    triple-black
    i ended up going w/ a 4-pt because of a X-mas sale going on @ Wolfe. was thinking 5-pt... 6pt not an option (my wife would kill me)
    I went w/ the mild steel cause w/ the weight diff and $-diff... it wasn't justifiable, imho... thinking again... i should've. Weld is more solid... lower maintenance, less risk of failure. For the carpet... a small incision making it perfect on the bar... looks nice finish.
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I went with 4 pt bolt-in steel with a removable x-bar. Because that all my local track needed.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    i have a wolfe 6 point, steel, both swingouts, and detachable back bar (behind the seats) i will be installing it in about a month i'll take pics for you if you want? mine is the bolt in but i will be adding some tach welds to. didn't think i was going to go with such a large motor.
    99 SS Vert M6
    Thanks guys. Keep'em comin.
    99 SS Vert M6
    Yes, I'd like to see that. I wish I could post pics. I've tried and tried.
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    Quote Originally Posted by Huskerz1 View Post
    i'll get you some, somewhat of a step by step.
    Jun 2002
    Montreal, CANADA
    triple-black
    oh yeah... my rear bar is also removable.
    Ed has plenty of pix... do a search on rollbar here, you'll find them.
    member HASTINGSRJ's Avatar
    Jan 2001
    Franklin, Mass
    00 SS Vert#0540/ 14 GMC
    6 point, bolt in, removable cross bar, and swing outs I havent put the swing outs in yet though
    Arizona
    I would like to see pics of how the bolt in attatches to the floor, particularly where it is most visable near the door entrance.
    I am also curious how back seat entrance is for rear passengers with the 4 point bolt in. Anyone have family that uses this?
    Unfortunately the ET cutoff is 13.50 which isn't hard to reach, and a bar may be in my future. I don't want to cut the car at all and would only consider a bolt in,,,as I may remove it when not at the track.
    Close up pics with the doors open and mounting procedures would really help someone like me decide if I even want to do this or not. Thanks,,,Larry.
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    Taking a cage in and out is not something that is easy or fun. Carpet removal and panel removal is required. Not something just ot jerk out real quick. The cage makes getting into the back a little more difficult, but with the removable bar that helps a lot.
    Arizona
    Doesn't sound like it's for me then,,,thanks anyway.
    99 SS Vert M6
    Nice lookin cage there HASTINGSRJ. I was very pleased to see that Wolfcraft is located here where I live. I will visit their operation.
    One question. Does any of the removeable stuff(crossbar and the swingouts) vibrate running down the road?
    Jan 2001
    Franklin, Mass
    Thank you. Yeah, Wolfe, definatly awesome people to deal with. When AMS (Arlington Motor Sports) fucked me over on this cage, I called Dan at Wolfe, and he sent me the cage. Great people! No vibration at all. The cage comes with pull pins for the cross brace, but I just put bolts in mine, since I dont have a back seat, and I really dont let a lot of people in my car anyways. Bolt in cages are really easy. It will take two people to install it. Me and Ed did mine in about 1.5 hours or so. It does require that you cut the carpet, and drill holes in the floor boards, behind the seats. The cage comes with all the hardware you need, bolts and steel plates for the bottom. The rear bars bolt up to the rear seatbelt mounts. I think that www.wolferacecraft.com they have instructions on their website. It will make the car a lot stiffer as well. Hope that helps you out.
    rob
    Black 00 SS M6, vert, #0540 408ci
    DD 2014 Sierra All Terrain
    Aug 1999
    No Where
    I agree with Rob. Great kit. Easy to install since we don't have a top to get in the way. No vibrations and you will get alot of looks.
    Jan 2001
    Franklin, Mass
    Quote Originally Posted by Ed Blown Vert View Post
    And all the ricers trying to race you too Or in Ed's case, a Ferrari calling you out of the bunch
    Aug 1999
    No Where
    Quote Originally Posted by HASTINGSRJ View Post
    You remember that run? The guy in the Ferrari
    Jan 2001
    Franklin, Mass
    I remember that one poor little ferrari got his feelings hurt
  1. Roll cages....I need one
    By 98TransAmWs-6 in forum Suspension and Handling
    Last Post: 05-21-2015, 08:08 AM
  2. Roll cages
    By Rk ws6 in forum Suspension and Handling
    Last Post: 12-02-2009, 10:42 AM
  3. Pictures of your roll cages! Please
    By james schofield in forum General Help
    Last Post: 10-23-2008, 06:27 PM
  4. Replies: 2
    Last Post: 02-11-2006, 06:37 AM
  5. Question about roll cages
    By RS_SS69 in forum Rocky Mountain Members
    Last Post: 02-01-2006, 06:48 PM
