Results 1 to 3 of 3
Thread: Window motor?
05-01-2007, 07:27 PM #1LoudMouth
- Jul 2006
- Westminster/Sykesville, Maryland
Red- 2000 Trans Am
Window motor?
Ok guys i just purchased a 1999 Trans Am. its not perfect but one thing that needs to be fixed as soon as possible is the passager side window. It goes up partially then stops, then after a few seconds it can go some more. This continues until its reached the top. Its the same way rolling it down. I assume that something is causing the Breaker to pop. Too much resistence caused by a bad motor?
05-01-2007, 09:40 PM #22002 Formula Firehawk
- Jul 2005
- San Diego CA
Black- 2002 Formula Firehawk
yes bad motor
http://www.ls1.com/forums/showthread.php?t=8307
05-01-2007, 10:35 PM #3
Very common problem in our cars, heavy window and no guide= worn out motors.
Not hard at all too replace and should only take about an hour and a few beers.
I would reccomend picking up a reman from say autozone because they come with a lifetime warranty so when it goes out again you will have it covered.
Window Motor
By new2dgame in forum General HelpReplies: 2Last Post: 06-22-2010, 12:34 AM -
need help with window motor
By 01pewterZ in forum General HelpReplies: 10Last Post: 12-17-2007, 11:10 PM -
Window Motor
By NewLS1 in forum General HelpReplies: 9Last Post: 12-17-2007, 03:53 PM -
Window Motor Mod??
By CamaroFan71 in forum General HelpReplies: 6Last Post: 10-12-2006, 07:36 PM
