Results 1 to 10 of 10
Thread: Drag racing ?
    Member Lawnman's Avatar
    Aug 2006
    lookin for a ws6
    Drag racing ?
    I have a a4, should I leave the car in drive or third? I tried third last time and was crossing the finish line @ 5100 -5300 rpm
    Junior Member nitroushane's Avatar
    Jun 2006
    maroon
    00 trans am
    I put mine in third when Im drag racing. That way it wont go into overdrive.
    Member GotN2O's Avatar
    NM
    Quote Originally Posted by nitroushane View Post
    same here
    Jun 2006
    maroon
    00 trans am
    The really debate is if you shift from 1st then 2nd to 3rd or if you just leave it in 3rd. Most people I have talk to say that your tranny will have more line pressure if you shift manually trough the gears.
    If you come in 2nd it just means you are the first to lose.
    Aug 2006
    lookin for a ws6
    Also I was told to lean on the convertor ? Is that where I have 1 foot on the brake and 1 on the throttle and bring the revs up until the tires are ready to break loose?
    Arizona
    I just leave mine in overdrive,,,it doesn't matter, as you will never get into overdrive in a quarter mile unless you run a ton of gear. I still have stock 3.23's in mine, and was crossing the finish line in 3rd gear at about 4500 rpms and trapping 104 mph. Not even close to using overdrive.
    I use the track to experiment all the time with tuning and driving both. You can try a pass in overdrive and a pass in drive and see how the car reacts. It's the best way to find what a particular car likes. Just try it and see.
    Member Rich L's Avatar
    near Atco NJ
    Burgandy
    2002 Z28
    Quote Originally Posted by Lawnman View Post
    Put it in "O" and floor it!
    2002 A4 Z28: SLP LM exhaust and HSW 100whp dry shot.
    NA: 323.4WHP@5360 RPMs, 344.2ft-lbs@4610 RPMs,
    N2O: 417.0WHP@5200 RPMs, 467.6ft-lbs@4210RPMs
    NA: [email protected], N2O: [email protected]
    http://www.youtube.com/watch?v=JMHmdFywR0w
    Member z28misfit's Avatar
    Jun 2006
    Fleetwood,Pennsylvania
    1999 Chevy Camaro Z28
    When I had my a4 95 camaro it did better when I left it in Overdrive. When I kept it drive it slowed me down alittle and shifting it was even worse. I think my best time if remember correctly was 13.717 at 100mph. Just play around with it and see what works best.
    99 z28 cam,m6 ,S60 4.56gears,Fast 90/90 full boltons,more mods one day.
    11.2 @ 123mph.
    Aug 2006
    lookin for a ws6
    So far my best was 13.6 @104. I was told the track is a slow track and should be able to run .4 - .5 better at other tracks. There was cars there running 13.3-13.4 and on other tracks they were running high 12's.
    Bolt-On Pimp ImpalaSSpeed96's Avatar
    ND
    01 Camaro SS
    Its different for each situation. If you have stock gearing it really shouldnt matter. If you have taller gears leave it in D because it will shift into OD when you will still be in your powerband of D. Each car runs differently though. Thats why its called test and tune.
    96 Imp SS- 12.74@103, 1.74 60' out of fuel
    06 AWD TB SS- 12.58@106, 1.76 60'
    01 Camaro SS- Totaled
  1. Drag Racing 101
    By ss_caramo in forum Drag Racing
    Last Post: 05-19-2020, 09:27 AM
  2. Drag Racing
    By andersonsmith125 in forum Drag Racing
    Last Post: 10-12-2011, 09:53 PM
  3. Question: drag racing help?
    By SSIZZLN in forum Drag Racing
    Last Post: 10-22-2010, 02:49 AM
  4. drag racing
    By woody84 in forum GTO
    Last Post: 07-13-2009, 11:26 PM
  5. Think you know Drag Racing?
    By skeet38 in forum Drag Racing
    Last Post: 04-25-2007, 07:09 AM
