    Vienna WV
    98 Trans Am
    Upgrading 98 to 99-02?
    Can you upgrade a 98 ecu to the newer style? Whats the difference? Is it a simple PCM swap or is it much more in depth??
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    more in-depth, the 98 has a different pin configuration (this is why some hand helds dont work for 98's or have different versions)
    to boot, nothing would be gained by upgrading.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Why would you waste your time?? There is no performance or functionality to be gained by switching PCM's between years.
    If you want to modify your PCM, get a tune. That will give you more performance, as well as better efficiency. Of course, its not going to help much on a stock motor, get some bolt ons and then have it tuned
    Vienna WV
    98 Trans Am
    Thanks I was wondering the difference between the two thats all. Thanks.
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by daveb91 View Post
    Okay, no prob
    Member cailey37's Avatar
    Mississippi
    1998 Pontiac Trans Am
    Actually the 98 ECM's have a slower processor in them.....they upgraded them in 99.....you can change it out but like someone said earlier....the pin outs are different.........but yes.....the 98 ECM's are a bit#$ to tune if you've done a lot of work to the car.....that's why I got rid of mine all together....
    I just read a write up on doing this switch today. It's definitely do-able. Just have to repin the harness. I read the write up at the "other" site.
  1. Upgrading HPtuner to Pro???
    By Firebirdjones in forum Computer & Tuning
    Last Post: 01-05-2011, 10:44 AM
  2. Upgrading from 16 inchers!
    By TransamNick in forum Wheels and Tires
    Last Post: 09-22-2009, 05:57 AM
  3. upgrading stereo
    By beer in forum Stereo and Electronics
    Last Post: 06-27-2009, 12:33 PM
  4. HID & LED upgrading
    By myk02k in forum Camaro / SS
    Last Post: 03-29-2006, 07:04 PM
  5. upgrading the 6 speed
    By transam98 in forum Manual Transmission
    Last Post: 10-04-2005, 10:55 PM
