Results 1 to 20 of 22
Thread: "Trip meter" keeps resetting
04-29-2007, 10:14 AM #1Junior Member
- Mar 2007
- Chicago, Illinois
Silver- 1999 Trans Am
It seems like every other day, my TRIP meter resets itself to 00000.
And come today, my car wouldn't start. So I took the battery to Autozone and they said it just needed to be charged. COuld that be what was causing the trip to reset?
04-29-2007, 10:42 AM #2Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
04-29-2007, 10:55 AM #3Senior Member
- Jul 2005
- Jacksonville, FL
Yep, low voltage. Sometimes it's accompanied by the gauges sweeping on start up too.
04-29-2007, 05:21 PM #4
04-29-2007, 05:48 PM #5
yep. loose cables and/or dying battery.
04-29-2007, 05:49 PM #6Junior Member
- Mar 2007
- Chicago, Illinois
Autozone was able to charge the battery for me since it was running low, now everything is starting and running fine.
04-29-2007, 10:23 PM #7
04-30-2007, 04:09 AM #8Junior Member
- Mar 2007
- Chicago, Illinois
04-30-2007, 02:11 PM #9Member
- Oct 2006
- Oklahoma City
00 LS1, WS6, V8 Gremlin- 96 & 98 GTPs, 64 'Cuda
Hate to be the bearer of potentially bad news but that's a sure sign of an alternator starting to go out. Take it off and let them test it.
04-30-2007, 04:18 PM #10
I just got my battery charged and mine is working perfectly now also (no sweeping) I can't beleive that wasn't normal. Its done it since I bought the car.
04-30-2007, 05:32 PM #11
Also, one of my side post things was coming apart or something. It was tight onto the battery, but the terminal itself was loose somehow is what the guy at Autozone said. I imaging that had something to do with it also.
04-30-2007, 05:38 PM #121999 Trans Am M6
SLP Short Throw, Lid and CAI, Strano Springs, Koni Sport Shocks, BMR STB and SFC, UMI PHB, Pacesetter LT's and ORY, Magnaflow Catback, DMH 3" E-Cutout, LS7 Clutch, Motive 4.10, 160 T-Stat, MSD wires,, 17x9.5 Chrome C6's wrapped in Hankook 275/40/17
Tuned at Mongillo Motors in New Haven, CT - 303 RWHP and 308 RWTQ
05-01-2007, 07:14 AM #13Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
05-12-2007, 06:48 PM #14Junior Member
- Mar 2007
- Chicago, Illinois
05-13-2007, 04:06 AM #15
this should really be a sticky in a thread "common f-body issues" or something like that.
05-13-2007, 04:09 AM #16Slow'er'Ass
- Thornton, CO
It isn't always the charging system that causes this.
There was an issue with the intrument cluster not seating correctly and failing on certain years.
Check the charging system first for sure, but it might be something else.
05-13-2007, 06:06 AM #17Senior Member
- Jul 2005
- Jacksonville, FL
Here's the TSB for the trip reset on the '99 cars - doesn't mention the gauge sweep but sometimes happens at the same time. http://home.earthlink.net/~cetera/pics/aug99tsb.jpg
05-13-2007, 04:28 PM #18
05-13-2007, 04:40 PM #19Senior Member
- Jul 2005
- Jacksonville, FL
Check the battery connections...and then have it load tested if it's still doing the same thing. Cluster is usually fine after installing a good battery.
05-13-2007, 04:40 PM #20
mine did this turned out the alt battery source was arching against the hood bc it was uncovered. elecetical tape fixed her right up.
Hussein Obama: Opponents to Iran "Deal" are "Crazies"...
By wileyCoyote in forum Political / Debate ForumReplies: 4Last Post: 08-26-2015, 11:11 AM -
Weather Channel Co-founder: "Climate Change" is "Not Valid"
By wileyCoyote in forum Political / Debate ForumReplies: 7Last Post: 10-24-2014, 05:44 AM -
my trip to the Vegas...aka "the trip of the Shoulda's"
By third_shift|studios in forum Almost Anything GoesReplies: 1Last Post: 11-18-2006, 04:33 PM -
"ROAD TRIP" Aug 18th - 21st
By HUGGER ORANGE SS in forum Rocky Mountain MembersReplies: 20Last Post: 08-02-2006, 03:35 PM
