Thread: Belt Squeal
    Junior Member camaromechanic's Avatar
    Washington DC
    2001 SS Camaro
    Belt Squeal
    I just wanted to know if any body else has had a problem with belt squealing? I changed both belts and it did not fix the problem. So i did a little more looking and have determined it is coming from the AC belt. So I am getting ready to change out the pulley there in hopes that it will stop the noise.
    Ga
    LeMans
    2005 Corvette 2005 GTO
    all the time or only after it rains?
    Washington DC
    2001 SS Camaro
    all the time
    Aug 2006
    Missouri
    94 Camaro Z28
    The squeal probably means that there is too much slack in the belt. Probably is the tensioner. Check the slack on the belt and try to adjust the tensioner as needed. Needs to be tight without a lot of play in the belt.
    Washington DC
    2001 SS Camaro
    It was tight but i will check it again. I want to pull it off again and see if i can feel anything with spinning the pulley by hand.
    Member Jon7I2's Avatar
    Chicago
    99 Formula M6
    Quote Originally Posted by BadBlueBird* View Post
    mine only does it after rain, what does that mean?
  1. Help: 2000 T/A ws6 belt squeal
    By dolfins1a in forum General Help
    Last Post: 12-15-2013, 04:45 PM
  2. my squeal is back...serpentine belt
    By leon phelps in forum General Help
    Last Post: 09-07-2012, 02:14 PM
  3. Help: Belt squeal?
    By yellowv in forum General Help
    Last Post: 11-26-2010, 10:01 AM
  4. Belt Squeal
    By redbird555 in forum External Engine
    Last Post: 10-02-2010, 07:17 PM
  5. Belt Squeal
    By vgm in forum External Engine
    Last Post: 04-11-2010, 11:06 AM
