    Oct 2003
    Charlotte, North Carolina, Uni
    2002 TT Camaro
    PTK results on stock engine at 7 PSI boost
    well I finally got the kit installed and dynoed 471 rwhp at 5100 RPM and 560 RWTQ at 3800 RPM
    I was expecting a little more HP and less torque but the clutch is slipping under boost and I think that it is almost toast
    my car is a 2002 Z-28 that is other wise stock with some supension mods
    now for a 9 inch rear and better clutch
    the turbo is a PTK kit with precision T67 with .96 exhaust housing and ptk front mount air to air intercooler
    all tuning was done by Alvin at PCM4less on Dan at Pro-Dyno's mobile dyno
    2002 White Z 28 former 6 speed car, APS twin turbo, 4L80E,
    9 inch Moser rear 3.50 gear,
    some other stuff, it is slow
    Owner/Administrator
    CarolinaRIDES
    Senior Member Hurley711's Avatar
    Earth
    414 RWHP 395 RWTQ
    00 Black Ram Air Trans Am
    Holy shit! What did the kit cost with install? How will the stock engine and internals hold up?
    Oct 2003
    2002 TT Camaro
    Quote Originally Posted by Hurley711
    I did the Install my self
    http://forcedinductions.com/GMkits3.htm
    this is where it came from
    and I spent alot more than that on stuff to go with the kit
    like fuel pump, injectors, boost controller, wideband, etc
    I think that I have about 6500 or 7000 in it now
    they should hold up like any other forced induction kit with 7 psi
    as long as it has a good tune it should be ok
    and a bad tune will make a built enginego BOOM
    LSLurker
    Guest
    sic
  1. Boost on stock inlet
    By mick08 in forum Forced Induction
    Last Post: 03-14-2011, 09:42 AM
  2. how much boost can i run on stock bottom end?
    By SmokinSS in forum Forced Induction
    Last Post: 07-22-2009, 12:17 PM
  3. APS twin results on 8 pounds of boost
    By Darren P in forum Forced Induction
    Last Post: 04-24-2008, 03:52 AM
  4. Building Engine for more BOOST
    By SilverStunna in forum Forced Induction
    Last Post: 07-17-2007, 08:51 AM
  5. PTK results on stock engine at 7 PSI boost
    Last Post: 10-17-2005, 06:55 PM
