Thread: How do I fit oil pan and covers?
04-26-2007, 02:12 PM #1Stroked Slowmaro
- Sep 2005
- East Tennessee
Silver- 2000 Z/28
I've been reading and have read that I have to fit the oil pan and the front and rear covers a certain way before I bolt them tight. Do I have to put gasket sealant in the corners? Any help would be great because I have only put early model small blocks together. Is there somewhere on the net that I could see pictures of this process. Thanks
04-26-2007, 04:03 PM #2
There are special tools designed to line up the parts square. I don't know the best place to get them as they can be expensive
04-28-2007, 09:19 AM #3
there are special tools you use to get them all lined up. but, if you take your time, you can get it all done without them. get the oil pan centered and snug first. then do the front and rear cover.
wheel to wheel has a rear cover seal install tool and centering tool. it's $275.00
http://www.w2wpowertrain.com/p-104-r...tall-tool.aspx
once you get everything centered, then torque to specs. oil pan first. then front and rear covers.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
04-28-2007, 12:26 PM #4Stroked Slowmaro
- Sep 2005
- East Tennessee
Silver- 2000 Z/28
Thanks. When I get ready to put the covers on I will probably see and understand how they work together. $275
seems steep for a couple simple looking tools.
t top covers
By troyaik88 in forum Camaro / SSReplies: 19Last Post: 06-24-2011, 01:34 PM -
center bolt valve covers, timing, valley and rear covers
By jjz28 in forum Parts For Sale / TradeReplies: 0Last Post: 09-05-2007, 12:14 PM -
center bolt valve covers,timing,valley and rear covers,crank
By jjz28 in forum Parts For Sale / TradeReplies: 2Last Post: 08-12-2007, 05:10 PM -
WTT Vette Fuel Rail Covers For Fuel Rail Covers
By LS1GMCTruck in forum Parts For Sale / TradeReplies: 1Last Post: 08-27-2006, 05:54 AM -
New value covers
By Trolleyman in forum External EngineReplies: 0Last Post: 08-19-2006, 11:10 PM
