    West Virginia
    2001 Pontiac Trans Am
    key switch Security wont let my car start sometimes ?
    I have a 2001 ws6 six speed that is my daily driver in the summer, and about one out of four times i try to start it, it wont, and the security light stays on. I figured it could either be the key or something in the switch, I havent had a chance to try my spare key yet. When it happens, the security light will stay on for 3 minutes, and it will not let it start till the light goes off, but as soon as it goes off, it always starts, any ideas?
    Tire Smoker Jeff2002WS6's Avatar
    Anderson, IN
    2002 Pontiac Trans Am WS6
    I had random trouble with my 96. I would just clean the dust and pocket fuzz out from around the diode in the key and it would work again.
    clean your key. there is oil or something on it that is contacting the security gizmo inside the keyhole and causing the computer to lock you out.
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    I had this problem once, except I was not able to start it with the key, period. Went to the Pontiac dealer and they told me that the key lost its resistance so it wouldn't read properly. He said they do wear out over time, however since it wasn't a GM key it took less time. It was a replacement that CarMax made, another one of the issues I've had with them.
    Member ls1speedster's Avatar
    Bethany, IL
    2002 trans am
    i also do have the same problem....
    just once that happens to me..i just sit in it lock it with my remote then unlock and see if that works...sometime it does and sometimes it dont...
    if not i just wait and turn it over multiple times to see....eventually it starts
    West Virginia
    the key didnt look dirty, but cleaned the key good and works great, thanks for the info
  1. Help: car wont start and now gauges wont work!
    By AB'sLs1 in forum General Help
    Last Post: 04-20-2013, 08:54 PM
  2. Help: My T/A wont start, security issue!
    By sdoyleT/A in forum General Help
    Last Post: 02-27-2011, 05:48 PM
  3. Security Light Blinking-wont start!!
    By BumCamaro in forum General Help
    Last Post: 04-30-2008, 06:54 AM
  4. Wont crank. Security light on.
    By yellowv in forum General Help
    Last Post: 07-30-2007, 03:59 PM
  5. security light, wont start
    By sic2001 in forum General Help
    Last Post: 03-02-2006, 05:37 PM
