Results 1 to 2 of 2
Thread: small skip????
04-24-2007, 05:28 PM #1Junior Member
- Mar 2007
- olean
white- 2000ss
small skip????
i just bought a 95 trans am ... its got some mods on it... lt4 hotcam... hooker comp headers upgraded accel ignition 410 gears... when im driving in lower rpms usually around 1500-2200 or so it gets a slight skip... i dont know .... it smells like it runs a little rich at idle.. is it possible iv got a bad plug.. or any other suggestions?
04-24-2007, 06:31 PM #2Member
- Oct 2006
- Oklahoma City
00 LS1, WS6, V8 Gremlin- 96 & 98 GTPs, 64 'Cuda
Could just be a point where the cam and everything else hiccups.
Always a good idea to change out the plugs and wires when you buy a used vehicle unless you're sure it was done recently AND done right.
One or more dirty injectors can also cause a rich condition. The partially clogged injector(s) don't spray as much fuel thus tilting the O2 sensor reading to lean which of course the PCM will try and compensate for by adding more fuel to the equation.
Skip Shift
By 10erg01 in forum Manual TransmissionReplies: 1Last Post: 12-11-2010, 10:22 PM -
1-4 skip shift
By 1stgto in forum GTOReplies: 13Last Post: 03-18-2010, 08:54 PM -
Help: a small skip
By 95Firebirdred in forum LT1Replies: 4Last Post: 12-08-2009, 11:29 AM -
skip that comes and goes
By dow inc. in forum General HelpReplies: 9Last Post: 11-09-2009, 03:52 AM -
Skip Shift
By urstolendesire in forum Firebird / WS6Replies: 19Last Post: 04-03-2007, 01:43 PM
