    NJ
    01 z28
    help with rings in the 01' ls1
    I had seen something in the past on this site about the rings on the 01 ls1 cars having smaller rings and causing oil blow by. I have noticed that sometimes my car does lose or burn oil. How bad is this and is this a chevy recall? Should I take it to chevy? I have the extended warrranty. Thanks.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    they have low tension oil rings. doubt you'd get any warranty work for it.
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    I think this is also an EGR issue change to a vette style.
    orlando, fl
    2014 camaro 2ss/rs
    the 01 has no EGR. are you thinking about the LS6 PCV valley cover?
  1. piston rings on a 98 ls1
    By Leeroyws6 in forum General Help
    Last Post: 05-19-2010, 05:04 AM
  2. What's New In Piston Rings
    Last Post: 09-09-2009, 01:40 PM
  3. Question: Bad Rings??
    By SpinsB in forum Internal Engine
    Last Post: 10-15-2008, 02:58 PM
  4. Looking for reluctor rings
    By trainingdragon in forum Parts Wanted / Trade
    Last Post: 07-23-2006, 12:46 PM
  5. Looking for reluctor rings
    By trainingdragon in forum Drivetrain
    Last Post: 07-16-2006, 11:38 AM
