04-24-2007, 10:17 AM #1
- O.C. California
Black- 2002 Camaro SS (crashed)
New front suspension installed *pic
here on a 2002 SS
UMI K-member
UMI chromoly adjustable upper and lower A-arms
Hotchik sway bar
Bump steer kit
Koni 8 way adjustable
Eibach sport springs
Wilwood 6 piston brakes
Motorsport 18x9.5 wheels
04-24-2007, 10:56 AM #2
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Nice setup.
04-24-2007, 11:21 AM #3
now that's pretty.
04-24-2007, 11:35 AM #4
- Pittsburgh, PA
GOOD GOD, i just spurt in my pants
04-25-2007, 06:09 AM #5
That looks like a decent install.
Did you get the K-member with the extra bracing, I can't tell from the pictures?
I have all those parts installed except for the K-member can you comment on the install, did you have to use a list for the engine, did everything line up right, what was the rate if difficulty in your opinion, etc?
04-25-2007, 07:21 AM #6
- O.C. California
-Yes, I ordered the k-member with extra bracing
-Install time was about 8 hours over 3 days. You know 3 hours here, 2 hours there. I didnt rush throught it.
-I used a car lift from work and supported the eninge with a transmission stand and one exhaust stand.
-There was only two parts that hung me up. The lower a-arm on the passenger side didn't matched up just right, even with the adjustments. And the steering rack was a bit tricky with all the hard lines. But this was my first attempt.
-On a side note: even with the stock cross member out, changing the sparks plugs was still a bitch. haha
Installed front end part...now I have codes
By ChevyZ76 in forum Camaro / SSReplies: 3Last Post: 06-28-2014, 03:47 AM -
Front Suspension Work / Completed Rear Suspension
By bhunter0830 in forum Suspension and HandlingReplies: 32Last Post: 07-02-2013, 01:23 PM -
By bhunter0830 in forum Suspension and HandlingReplies: 0Last Post: 04-13-2013, 05:44 AM -
installed some suspension parts,
By 98maro in forum Suspension and HandlingReplies: 24Last Post: 10-21-2011, 10:21 AM -
Help: Installed new suspension and can't put my strut to
By Octavain in forum Suspension and HandlingReplies: 4Last Post: 03-31-2010, 12:53 AM
