Results 1 to 18 of 18
Thread: Pulled the motor..
10-17-2005, 11:13 AM #1
Pulled the motor..
So.... Once I found this:
I decided to go ahead and pull the motor..
My brother -- I SWEAR he's adopted...
10-17-2005, 11:13 AM #2
My lil helper..
Front end is a lil taller..
10-17-2005, 11:33 AM #3Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Good luck man. I hope everything goes good. Are you going to do a complete rebuild with new cam, pistons, or what you gonna do?
10-17-2005, 11:59 AM #4
Haven't exactly decided yet..
10-17-2005, 06:03 PM #52mff-Z28Guest
Looks like fun...........good luck.
Must the heads be removed to get the motor out the top? looks like it but I'm not sure
10-18-2005, 05:10 AM #6
It can be done without pulling the heads.. We just wanted to make it as easy as possible to pull.
10-20-2005, 05:42 PM #7Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
you mean u just didnt want to move the car out the garage
seems like everyones shit is broken down
10-20-2005, 05:52 PM #8
and mine is still not running
Good luck with it Steve......
Black 00 SS M6, vert, #0540 408ci
DD 2014 Sierra All Terrain
10-20-2005, 05:54 PM #9
How did you burn that bearing like that?
10-20-2005, 06:53 PM #10Senior Member
- Aug 2003
- Honolulu HI
not paying attention to his oil level
10-21-2005, 04:24 AM #11
10-21-2005, 10:23 AM #12
d-oh-if it's any consolation-it happened to me w/a 327 some years ago.S#@t happens.
10-21-2005, 12:00 PM #13
actully it can be reomved fromt he bottom. the whole k member comes out of it. suspension and everything. i think that would be easier.
10-21-2005, 02:14 PM #14
I think the question there is where would you hook up the cherry picker to the body?I mean in a shop you use a rack and lift the body up off the k-frame-with a cherry picker you would pick the body up,or would you.Anybody done this?
10-21-2005, 03:52 PM #15what i would do if i were doing it. i would jack the entire car up, support it on jackstands. put a jack under the motor, unbolt it, let the jack down on the engine, bring it out from in front.
Originally Posted by 02z28ls1
10-22-2005, 08:00 AM #16Senior Member
- Aug 2003
- Honolulu HI
i pulled it from the top....wasnt hard at all...
10-23-2005, 09:39 AM #17
I pulled mine from the top too. It can be done and considering I don't have a lift in my home garage, it was pretty mich the only option. On a darker note, my car is still down too!
10-23-2005, 04:05 PM #18Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Howdy again
Man this is a perfect oppurtunity to preach on oil aint it
...look at that varnish and the carbon on the pistons....ouch...no wonder the bearing shit the bed. You need a catch can looking at that carbon on those pistons....and some serious consideration to a quality oil with reasonable OCI's.....Clean the shit out of your intake before you slap her back on...get a catch can....good luck with your engine rebuild...
got pulled over....
By War Theory in forum Almost Anything GoesReplies: 31Last Post: 07-19-2010, 06:23 AM -
Well I pulled the trigger!!!
By Z28Thunder in forum Gun's & AmmoReplies: 15Last Post: 02-22-2010, 09:04 PM -
Pulled over
By rjasso1 in forum Almost Anything GoesReplies: 7Last Post: 07-07-2008, 06:43 PM -
Got pulled over, I think maybe he was having a bad day...
By DrMilhouse in forum Almost Anything GoesReplies: 26Last Post: 05-31-2007, 07:55 AM -
Pulled over :)
By jrc1122 in forum Firebird / WS6Replies: 17Last Post: 05-10-2007, 08:35 PM
