Results 1 to 10 of 10
04-22-2007, 12:29 PM #1
- Apr 2007
- Bentonville, AR
Navy Blue Metallic- '02 Trans Am WS6
Cam Help for Lightly Modded 02 WS6
I'm trying to decide on my cam swap and need a lil advice. I don't wanna go outragous but I want something that is gonna lope pretty hard. By the time the cam gets installed car will have the following:
Ported Heads with New Stainless Valves and Recommended Springs
Ported TB
Weiand Intake
Aeromotive Fuel Rails w/ New Injectors (36lb be good?)
1.8 Shaft Rocker
Comp Hi-Tech Pushrods
Double Roller Timing Chain
MSD Coil Packs
Kooks Headers and Off-Road Y-Pipe
Corsa Cat-Back
I was thinking like a .560 Lift, that be too big? I want it to stay a Street Racing/Road Course car.
04-22-2007, 12:39 PM #2
04-22-2007, 02:41 PM #3
- Cape Coral, FL
Mystic Teal- 99 Trans Am & 01 CBR 929
keep 1.7 rockers can you can go bigger with the cam. there is no need for the 1.8 and they will greatly hinder your cam possibilities. the lift you are thinking would be fine, you should be fine all the way up to .600 but the duration matters more and that is what will determine how your car behaves. just poke around at some of the other cam threads and check out the advise given to other people.
04-22-2007, 06:35 PM #4
- Dec 2002
- n/w chicago
a few bolt ons, 379 rwhp
11.96 @113.25
04-22-2007, 06:52 PM #5
vinci xxx
http://vincihighperformance.com/CAMS...%20LS1%202.htm
in a road racing application, the 115 LSA will give a nice long powerband.
and keep the 1.8 shafts.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
04-22-2007, 07:13 PM #6
- Feb 2007
- Bakersfield, CA
86 Buick Grand National- 02 WS6-M6 407 RWHP
Just wondering i bought tsp's 228/228 .588/.588 114 cam how much power am i giving up if i would have gone with the 112 lsa
04-22-2007, 07:25 PM #7
not much. just lenghtens the power band and changes the peak points.
04-22-2007, 07:35 PM #8
- Feb 2007
- Bakersfield, CA
Ok thanks, because after intalling it i wasn't second guessing my decision to go with the 114.
04-23-2007, 04:55 PM #9
- Apr 2007
- Bentonville, AR
Is it possible to swap the 4 and 7 firing order like I did in my dirt car? That really broadend up the power band alot. Is the firing order the same as the pre 85 blocks? We ran those with carbs.
04-23-2007, 06:27 PM #10
no. GM changed the firing order for the LSx motors.
SBC and LT1
18436572
LSx
18726543
What is your fuel mileage on your stock/lightly modded 4th g
By elwood in forum General HelpReplies: 18Last Post: 01-14-2011, 10:54 PM -
Me VS Lightly modded C6 Z06
By 2000T/A Guru in forum Kill StoriesReplies: 37Last Post: 05-02-2007, 10:55 AM -
Which is better modded?
By pyro71985 in forum Almost Anything GoesReplies: 22Last Post: 11-07-2006, 11:46 AM -
modded c6 zo6
By blue02Z in forum CorvetteReplies: 3Last Post: 11-01-2006, 10:42 AM -
1987 GN 21,800 Miles-Lightly modded
By AintNo8 in forum Vehicles For Sale / TradeReplies: 10Last Post: 08-31-2006, 05:38 PM
