Results 1 to 11 of 11
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    Unhappy Drivers side window stopped working!
    I was cruising today and put my drivers side window up and down a couple of times. It worked no problem not slow or anything. The motor was replaced about 2 years ago. When I went to put the window up about 15 minutes after putting it down the window would not go up! It puts a hit on the volt meter if I push the switch so it seems like the switch is working ok. I don't hear any noise of any kind. Any guess on if the motor just up and died with no warning or does a connection sound more logical? The other window works fine as well as all other electronics. There are no blown fuses.
    Member 02WS6dream's Avatar
    Jun 2006
    Charlotte, NC
    2001 Trans Am WS6
    exactly what mine did when it died last summer... did you get an aftermarket replacement motor with a lifetime warranty???
    my *guess* would be the motor but either way you'll have to just start tearing it down and checking things.
    WI
    Blog Entries
    1
    It was winter when it went out last time and I had a shop do it. I think it was a new GM one. I had an extended warranty then and didn't care what they used. I never heard of them just dying without warning. Last time it would get stuck going up and go very slow. I'll see if can find my paper work from last time. I'll take the door panel off during the day tomorrow after I get some sleep. I'm on the night shift tonight. I had to drive the wife's Eclipse. I don't know how she can stand driving it all the time!
    WI
    Blog Entries
    1
    I do know what started this problem. I washed the inside of my windows last Sunday for the first time since fall!
    Aug 2006
    mn
    1998 trans am
    I just had to clean my connections out they were all corroded
    WI
    Blog Entries
    1
    I hope that's the only thing wrong with mine! I didn't get at it yesterday. Hopefully after a nap this morning I'll get some time to pull it open today.
    WI
    Blog Entries
    1
    I pulled the window motor last night and tested it with a power supply. It worked, but very slow and the gear would wobble around quite a bit. It was a AC delco one. I put it back in for the night to keep the window up while I'm at work and it does work slowly. I'll be picking up a new one from Autozone tomorrow. I noticed my back anti-rattle window felt pad is broken. I need to order one of them too. That explains why my window was rattling when it was half way up!
    Aug 2006
    mn
    1998 trans am
    Ah sh** I think thats what was up with mine I put in some new gears in my window motor but they stripped right away...
    WI
    Blog Entries
    1
    If your gears are stripping I'd think the regulator would be messed up making to much resistance or the motor is not in a good position.
    Aug 2006
    mn
    1998 trans am
    what do I have to do to fix the regulator? The motor is bolted down pretty good, I din't know I could change the motor position. On the up cycle the bar doesn't hit the stop Im not sure what the heck is going on. it suck though
  1. I need a drivers side window!!
    By johnnybravo in forum Parts Wanted / Trade
    Last Post: 10-02-2008, 03:49 PM
  2. Drivers Side Window?
    By SSNAKEATER23 in forum General Help
    Last Post: 12-28-2007, 12:31 PM
  3. *Drivers side window, help! =( *
    By SicWs6 in forum Firebird / WS6
    Last Post: 07-13-2007, 07:12 PM
  4. need drivers side window
    By 96Z28LT1 in forum General Help
    Last Post: 03-21-2007, 05:52 PM
  5. Drivers side key lock isn't working
    By 86 IROC-Z in forum General Help
    Last Post: 10-22-2006, 09:54 AM
