Results 1 to 14 of 14
Thread: Differential Help
04-20-2007, 03:18 PM #1I see Yello and I like it
- Mar 2007
- Ontario, Canada
yellow- 02 Collector Trans Am
Differential Help
I just bought my 2002 trans am in Feb and had it in storage until yesterday. The differential cover was seeping alittle bit. I took off the cover to change the gasket and re-silicon it but when I took it off there were little chucks of steal in it. They look like parts of the teeth. All the visible gears look fine so im assuming its coming from the spider gears. Im not sure? It this something I should worry about immediately or wait until the diff gernades? Or is this common and can go for a while like this? Please let me know. Thanks.
04-20-2007, 03:29 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
Can you post a pic?
04-20-2007, 03:49 PM #3
Well you say it looks as if the pieces came from teeth....... How big are the pieces? Compare them to something we can relate to.
If it is from the spider gears 80% of the time it is from the limted slip being burnt and someone doing JohnForce 1 wheel peel burnouts.
When only one wheel spins and it's going a 100mph and the other is rolling 5-10mph the spider gears inside are going 300. That is what usually breaks them.
Depending on how big of pieces they were would determine if you should fix now or wait for....
How many miles are on the car also?Don't be afraid of the bottle!!! Be afraid of your tune!!!
04-20-2007, 04:50 PM #4I see Yello and I like it
- Mar 2007
- Ontario, Canada
The car has just under 50 000 miles and the pieces are very small (about the size of a the tip of a broken off pencil). There were about 50-60 of these in there along with metal fillings on the magnet. The car has tcs if that makes a difference and there doesnt seem to be any rear end noise. Thanks.
04-20-2007, 04:57 PM #5
Put some good synthetic fluid in it and call it good then!!!
04-20-2007, 05:02 PM #6I see Yello and I like it
- Mar 2007
- Ontario, Canada
After all the oil was drained, I cleaned it all up with brake cleaner then put the cover on and filled it up with synthetic. I just didnt know how worried I should be about this. Will it likely just blow up or will there be some warning signs? Thanks alot for this info.
04-20-2007, 05:36 PM #7
usually You'll Get Some Whines Or Grinds Before Hand.
04-24-2007, 01:12 PM #8I see Yello and I like it
- Mar 2007
- Ontario, Canada
I cant see the spider gears on my rear end. Is that normal for these cars or has a racing differential been put in? Please let me know.
04-26-2007, 04:48 AM #9
It all depends on what carrier you have. It could be the design of the housing to where the inner is not that visable.
04-26-2007, 05:34 AM #10I see Yello and I like it
- Mar 2007
- Ontario, Canada
It is that design...you cannot see the spiders. Does that mean I need to use an additive?
04-26-2007, 05:48 AM #11
04-26-2007, 06:00 AM #12I see Yello and I like it
- Mar 2007
- Ontario, Canada
I used the synthetic diff oil right from GM. Im not sure if it had the additive or not. Will it say on the bottle?
04-26-2007, 06:06 AM #13
It should have a footnote on the back saying something about the additive being needed for LSD.
04-26-2007, 06:09 AM #14I see Yello and I like it
- Mar 2007
- Ontario, Canada
alright, I will take a look. Thank you for the info.
How do I know what differential?
By patriot1136 in forum DrivetrainReplies: 3Last Post: 06-11-2008, 09:05 AM -
differential
By jimmybling31 in forum DrivetrainReplies: 0Last Post: 04-22-2008, 11:23 AM -
differential help...
By jason1300 in forum CorvetteReplies: 4Last Post: 02-25-2008, 03:58 PM -
New Differential
By Redstaff in forum Automatic TransmissionReplies: 0Last Post: 07-07-2007, 09:15 PM -
M6: 3.42 vs 3.73 differential
By tici in forum DrivetrainReplies: 58Last Post: 12-07-2005, 03:14 PM
