Results 1 to 20 of 38
04-18-2007, 01:01 PM #1
Crying... Starter snapped off - Need advice
Hello again guys and gals.... Got underneath her today and found that my starter was snapped off, so even though it was operational, the gear wasn't making contact to crank.... One bolt mount on the starter was broken off, but my problem is that the other bolt broke with the carbody side mount.
Two Questions :
1. Is that the bell housing that it is mounted to ??
2. If it is/isn't, does anyone have an idea of $ wise, the cost of replacing the housing where it snapped ?
Thanks in advance.....
(currently in mourning)
04-18-2007, 10:43 PM #2
- Apr 2007
- Bellingham , WA
89 porche Red- 1970 Camaro RallySport
usally the starter is bolted to the block , what did u break the bolts or the ear of the starter?
04-18-2007, 11:47 PM #3
sure that's not just the starter that broke where the bolt passes through it? I just went out and looked at mine and that looks like the back of the block that the bolts actually thread into. How in the heck did you break that? That's a pretty thick chunk of metal.
04-19-2007, 07:25 AM #4
I have an LS1 on the engine stand, and would be more than happy to post some pics of the starter, and where it mounts on the block for you if it would help. They will show up later today on my fquick under the 67 Camaro at
http://www.fquick.com/67RSSS
Put up a pic of the starter and the location it mounts. Note that the block is upside down. Forgive the mess, just getting ready to clean the engine up....Last edited by 67rsss; 04-19-2007 at 07:34 AM.
04-19-2007, 07:36 AM #5
04-19-2007, 12:27 PM #6
A BIG THANK YOU for all who responded, especially with the pics and info.
Here's my miserable update..... She's on a lift now, and you can see in the pic attached what gave.... The inner hole and thread are good....the starter mount broke there.... But the outer corner of the outside hole cracked.
I have two painful problems.....
1. trying to find an alum welder to weld that broken piece back (if possible)
2. making sure the engine isn't damaged by possible water-lock... I was able to manually turn the crankshaft w/ plugs in ( 2 piston / valve compression cycles ) but believe I still might have some water in there.... What happened was I went through (and subsequently stalled out) in a flooded area that came up to the bottom of the door sill, but just not enough to spill into the car with the door open. Was only going about 5 mph to get through it, but she stalled....I did try to start her once (like an idiot....I'm still kicking myself) then pushed her out. I probably snapped the starter off in the water when I tried to start it.
Wish me luck guys..... I'm still crying.
Attachment 11527
04-19-2007, 12:42 PM #7
- Feb 2006
- MD
Delco-Remy has issued a starter with a new design specifically to combat this problem. You will no longer have 1 short and 1 long bolt. Been around for almost a year now, yet you never see anyone mention it on any of the LS1 sites...
04-19-2007, 01:17 PM #8
04-19-2007, 01:42 PM #9
- Feb 2007
- Pa
Red- 99 TA
can you take a few pictures of the damage? maybe someone has some ideas.I'm thinking if you broke off the starter you may have bend a rod or worse.I would pull all the plugs and turn the engine over by hand.should turn free and evenly no binding.depending how the block broke it may be possible to fab some kind of starter mount that you would need to drill new holes to mount.i'm thinking maybe using the new design starter with some kind or bracket to attach the outside bolt might get it.rigged for sure but at least it would get you started.looking at the pictures above i can see one posible solution would be fabing a cover plate that bolts to a new hole drilled into the starter mount,then machine the plate thickness off the new starter.the outside bolt would then thread into the plate.
04-19-2007, 02:51 PM #10
I will post pics tomorrow.... You are reading my mind.... I think I can fab a bracket that will mount between the block and the bell housing using the two existing bolts holding the block and bell together.... 90 degree angle bracket will then be in position of broken hole of block with (i guess) a threated tap plate..... maybe..... I do like the idea of also modding the starter and maybe threading it there.... Hmmm. So far, thanks a mil for the responses and ideas...
04-19-2007, 03:06 PM #11
- Apr 2007
- Bellingham , WA
wow , yeah i thik ur skrewed on that one, ur gona have to fab up some type of bracket like they were sayin , oh man have fun with that
04-19-2007, 03:20 PM #12
- Feb 2006
- MD
04-19-2007, 03:36 PM #13
- Feb 2006
- Orange County, NY
where in ny are you?
04-19-2007, 04:12 PM #14
04-19-2007, 04:23 PM #15
- Feb 2006
- Orange County, NY
out on long island. i have a friend who tig welds, but he is lives out further than me.
04-20-2007, 10:39 AM #16
Here's the pics of the damage... I put in a claim, and we'll see how much they'll gimme for an engine... Depending on price, I'll either drop a new LS1 or a new LS6 in her depending on the amount they'll pay.
04-20-2007, 10:59 AM #17
That can be fixed, but not with it in the car. A good TIG welder should be able to make it as strong as new, and for a whole lot less than the cost of a new motor.
04-20-2007, 05:44 PM #18
- Feb 2007
- Pa
Red- 99 TA
wow i;d be looking for more damage after seeing that.took alot to break that starter off.
04-20-2007, 08:17 PM #19
04-20-2007, 08:32 PM #20
tig it, damn that motor needs to be pulled
Oh for crying out loud
By GTP231 in forum Political / Debate ForumReplies: 55Last Post: 09-09-2010, 03:21 PM -
My girlfriend just called me, crying.
By 86 IROC-Z in forum Almost Anything GoesReplies: 45Last Post: 08-21-2010, 08:06 PM -
I have been crying
By c5z28 in forum Almost Anything GoesReplies: 14Last Post: 02-24-2009, 03:30 PM -
So, my GF woke me up at 3:30 am Crying.
By Hi-Po in forum Almost Anything GoesReplies: 39Last Post: 12-21-2008, 11:58 AM -
neighbor crying about exhaust
By KC&97TA in forum Western MembersReplies: 85Last Post: 02-20-2007, 05:44 PM
