    Junior Member bellboa1's Avatar
    Saskatoon
    2002 Z28 SS #105
    02 SS rear tire sizes?
    I have an '02 SS just wondering what is the widest tire you can put on the original 17" wheels(zr1) Pls Help before I have to go buy 275's again!
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    315's but its better to go with a wider rim, and if you do so, the inner fender wells will need a bit of persuasion
    DFW
    '18 CTS-V
    '13 ZL1
    stock rim = 17"x9"
    stock tire size = 275/40/17
    here read this, it might help you, it may not...
    http://www.ls1.com/forums/showthread.php?t=46586
    2013 ZL1: °°590rwhp/576rwtq°°
    11's HERE I COME INIT2WIN's Avatar
    Louisiana
    2002 Camaro Z28 A4
    I would had some 285's on the back of my car with no problem. I have 18x9.5 rims though that is only a 1/4 of an in wider per side. that Isn't much. I was going to go with some 295's next time but I am getting rid of the rims.
    d
    2002 z28
    Quote Originally Posted by ss~zoso~ss View Post
    will any 10.5 fit no problem w no persautaion or is just going w a 10" better just to be safe
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    Quote Originally Posted by bellboa1 View Post
    Welcome to the board, fellow Canuck !
    on stock wheel, 17x9" you should not go wider than 275/40-17
    note that 275/40-17 is meant to be installed in a rim width of 9.0-11.0
    for instance a 315/35-17 is meant to be installed in a rim 11.0-13.0
    Unless you don't want the tire to be properly mounted, I'd stick w/ 275s.
    If you want to go wider... get a wider wheel... I love wide too
    Eugenio_SS
    Jun 2002
    Montreal, CANADA
    triple-black
    Quote Originally Posted by greatwhiteZ28 View Post
    it really depends on the offsets.
    in the rear you can fit a wheel upto 11" with nothing much to do... while in the front you can fit a 12" wheel without any mods.
    It really depends on the offset.
    I have 17x11 on all corners and i can rotate
    pix on link of sig.
    Saskatoon
    2002 Z28 SS #105
    Thanks everyone. I appriciate
  1. tire/rim sizes
    By stangsr4loosers in forum Wheels and Tires
    Last Post: 10-07-2008, 08:51 AM
  2. Question: tire sizes?
    By cramn4903 in forum Wheels and Tires
    Last Post: 04-15-2008, 12:37 PM
  3. Tire Sizes????
    By mpunklil in forum Wheels and Tires
    Last Post: 10-13-2007, 12:46 PM
  4. Different tire sizes
    By hllywd in forum Wheels and Tires
    Last Post: 03-15-2006, 05:29 PM
