Thread: Rear rotor removal, help needed
04-14-2007, 08:20 AM #1Member
- Sep 2005
- Southeast PA
Black- 2000 Z28
Ok, so I'm trying to replace my pads and rotors. The front rotor came right off after I took the caliper bracket off. The rear doesn't seem to want to budge.
Any ideas? I only have 1 side of the car up off the ground, but that shouldn't make any difference, should it?
04-14-2007, 08:25 AM #2Slow'er'Ass
- Thornton, CO
E-brake needs to be off.
Sounds stupid...but I have forgotten it before as well. Just habit to put in on.
04-14-2007, 08:39 AM #3
Sometimes they get siezed to the axle, take a block of wood and put it behind the rotor and hit it with a hammer. The wood will protect the rotor from damage. Also hitting the face of the rotor will help as long as you don't the a lug stud. (By face of the rotor I mean the hub area not where the pads touch)
It may help to spray some WD40 or rust penetrate through the lug stud holes.
Also make sure you put at leats one lug nut on loosly so when the rotor does free up it doesn't go flying off.
04-14-2007, 03:54 PM #4Member
- Sep 2005
- Southeast PA
Black- 2000 Z28
I ended up going out and buying one of those $20 propane torches. As I was heating the area between the lugs and the hub water started seeping out. After that a couple taps with a hammer and they both came right off.
04-14-2007, 05:31 PM #5
04-14-2007, 05:41 PM #6SMKDFRDGuest
Use a little WD-40, take a mallet to in and it should just pop off.
04-27-2007, 09:51 AM #7
Help: Rear Rotor removal
By psycho_puppies in forum General HelpReplies: 17Last Post: 11-07-2011, 05:50 PM -
Wanted: Baer rear rotor's
By MUDDOG in forum Parts Wanted / TradeReplies: 1Last Post: 02-11-2010, 08:26 PM -
Help: Rear Brake Rotor
By Black Dragon WS6 in forum General HelpReplies: 3Last Post: 06-20-2009, 10:47 AM -
Rotor information needed
By tomekz28 in forum Suspension and HandlingReplies: 0Last Post: 08-28-2007, 01:48 PM -
rotor removal
By jeanluc in forum General HelpReplies: 7Last Post: 01-28-2006, 07:55 PM
