Thread: 98 pcv question
    98 pcv question
    I'm swapping my 98 heads for the center bolt 5.3's. The valve covers I got are different. The passenger side cover is missing the rear fitting for the crossover tube. I don't want to convert to the LS6 pcv so I'm trying to figure out a non-ghetto way of making these work without looking ghetto. The baffles on the underside of the covers makes it tough to do much as far as drilling and putting in a fitting for the crossover. I also don't really want a breather sticking out of the cap. Any other ideas?
    I've thought about drilling a hole into the side of the fill tube below the cap and putting a fitting there to connect the crossover to. I could do it down low on the tube so it wouldn't stick out to much. Think it would look ok? I'm just out of ideas and am not real crazy about cutting on the block and converting to the LS6 style valley cover.
    SE of Pittsburgh PA
    1998 Pontiac TransAM WS6
    I just did a similar swap.
    The original right valve cover has 2 vents, and the left only has one. The new ones only have one vent on each side.
    What I did was pull the rear vent off of the original valve cover, and measured the hole. I think 25/64 is what mine was. Then you will have to find the casting mark on the replacement right valve cover. Mine was on the side instead of the top. Drill the hole, and pressed in the vent pipe. Some cutting of the original hard plastic tubing is necessary. When I was done, it looked just like before. Notice on the Right that the PVC valve is in the original location.
    Check it out at
    http://www.fastbros.com/Right.JPG
    http://www.fastbros.com/Left.JPG
    Tracey
    Quote Originally Posted by traceymccabe View Post
    Check it out at
    Tracey
    Nice. Thanks for the info and pics.
    SoCal
    Mag Red
    '98 C5
    All I did on my '98 Vette was buy a PCV valve and cut the bottom out to get rid of the check valve. Works perfectly w/the newer style center bolt valve covers.
  1. speedometer question + top speed question
    By Krazy351w in forum General Help
    Last Post: 06-21-2007, 05:51 PM
  2. HPIII question (not the same old question)
    By slims00ls1z28 in forum Computer & Tuning
    Last Post: 06-01-2007, 04:55 PM
  3. 97 Bird Headlight question also engine noise question
    By Zapper2003 in forum General Help
    Last Post: 12-13-2006, 03:03 AM
  4. Speedometer question, RPO question
    By acrylicophobia in forum Firebird / WS6
    Last Post: 11-02-2006, 07:08 AM
  5. Sex Question spinoff- PORN QUESTION
    By egaian in forum Almost Anything Goes
    Last Post: 07-26-2006, 03:07 PM
